Old 09-23-2009, 05:40 PM   #1
Trader Rating: 17 (100%+)
Default xray T2007 spur gear blocking screw holes for motor
I am wondering what everyone has done about this issue that I am having
are you running a bigger spur and a smaller pinion??? or vice versa
right now I have a 96tooth 64 pitch spur and a 33 tooth pinion and I can get at the screw hole, but I don't have anymore adjustment between the pinion and the spur, basically it isn't meshing properly
any help would be appreciated
Mike
pantherblack is offline   Reply With Quote
Old 09-23-2009, 05:47 PM   #2
Scott B's Avatar
Trader Rating: 43 (100%+)
Mike
You need to run Xray gears or the RW "Xray" gears that have holes in them to put your hex driver thru to get to the screw.
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 09-23-2009, 05:48 PM   #3
Satish's Avatar
I had this issue aswell with mine. What i did was used my reamer and made one of the holes in the spur gear bigger. Then it was no problem getting at the motor screw.
Hope this helps ya out
s
Satish is offline   Reply With Quote
Old 09-23-2009, 05:49 PM   #4
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
I have only used Xray spurs on the car which have holes to get the the motor screws.
Sean
HB/HPI Racing | Morgan Fuels | HOBBYWING | Airtronics | REDS Racing | HRP | Hobby Revolution | Team N.E.R.D.
BLKNOTCH is offline   Reply With Quote
Old 09-23-2009, 08:10 PM   #5
Trader Rating: 33 (100%+)
I've had this as well, the RW gears work well as they have the holes to get to the screw, the XRay's do too but they don't go small enough for me. If I don't have a RW spur then I usually take the upper decks off, set the mesh, tighten the front screw, then lift the spur assembly to access the rear screw then put everything back together. Pain in the butt I know, but that is the only way I have been able to do it without drilling a hole in the spur.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 09-23-2009, 08:33 PM   #6
Alright thanks for the replies, I just ordered 4 different xray spurs and 4 different pinions
Old 09-23-2009, 09:13 PM   #7
niznai's Avatar
That's the way I do it too. I got rid of the Xray spurs for I see no reason to buy theirs when I have all the spurs I need already and I don't want to drill any of them.
What FDR are you aiming for panther, by the way?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 09-23-2009, 09:24 PM   #8
maybe about a 4.75 to 5.5 depending on track layout
I have an assortment of 64p spurs and pinions coming
Old 09-23-2009, 09:42 PM   #9
niznai's Avatar
You will need some huge pinions to achieve that ratio with 64 pitch as the adjustment range of the motor is very limited. The car was not really designed for brushless and especially for high wind motors. I had to modify the internal ratio of the car to get back to some human size pinions.
Team Greasy Weasel
Old 09-23-2009, 10:12 PM   #10
sorry, I posted the Primary gear ratio
I am not sure of a FDR yet, what would be good for my application?
I am running a T2 007, LRP TC sphere, smc 3200 and 5000 2S lipos, novak 13.5
track will not have that much grip, and the track will be quite curvy
Mike
