Old 02-06-2004, 04:00 PM   #1
Rob Hochberg's Avatar
Send a message via AIM to Rob Hochberg
Default Lrp Ipc Sr Esc
Does anyone know how to turn up the punch setting? Mine didn't come with a manual, I acquired it in a deal, I'm just using it because my Q1 decided to not work on me about 2 weeks ago. Also, the thing doesn't have any brake. I turned up the dial all the way, still nothing, I set it up right, and did it a few times to be sure, is there something wrong, or a way to turn it up? Thanks, -Rob
Rob Hochberg is offline   Reply With Quote
Old 02-06-2004, 04:02 PM   #2
microRCshop's Avatar
microRCshop is offline   Reply With Quote
Old 02-06-2004, 04:09 PM   #3
rc-zombies's Avatar
punch setting is not adjustable... I think...it's been awhile since I set mine....
Old 02-06-2004, 08:17 PM   #4
Did you get the chips with it? The manual tells you to use chip 65 for stop. I found that I like to use the 80 chip. It has increased the punch.
Steve
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 02-06-2004, 08:19 PM   #5
I use the 120 chip for 19T TC and 80 for stock TC. I have to IPC SD and the V7.1
Steve Walter
Old 02-06-2004, 08:27 PM   #6
Unfortunately, I did not get the chips. I guess I'll have to live with it, I'll turn the brake up on my M8 too.
Old 02-07-2004, 02:39 AM   #7
If you do not have the chips, you are running maximum punch
dhiracing.com is offline   Reply With Quote
Old 02-07-2004, 07:24 AM   #8
Oh! Good!
Old 02-07-2004, 08:07 AM   #9
lem2's Avatar
Default SR IPC
Personally, the SR works better and is more punchier with out the Chip
Its launch control is better than the V7.1, on a full stop, hit the brakes for 10 seconds then throttle!!!!! Vrrrrroooooom!!!!
lem2 is offline   Reply With Quote
Old 02-07-2004, 09:59 PM   #10
Yeah, the Q1 had that too, I used that little feature quite a bit!
Old 02-08-2004, 09:35 AM   #11
pheyhoe's Avatar
R/C Tech Charter Subscriber
has the dominator EVO and the LRP quantum comp 2 got that feature also?
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 02-08-2004, 10:00 AM   #12
lem2's Avatar
dunno withthe Dominator but withthe Q2--yes it has that feature!
Old 02-08-2004, 03:05 PM   #13
I race 10th scale stock oval pancar. I have a tekin g12c3 speed controller. I am thinking of upgrading my speed control. Would a lrp quantum 2 help me or is it not good for oval. What does anyone think? What would you move to if anything?
ddesens is offline   Reply With Quote
Old 02-08-2004, 03:18 PM   #14
JusBox's Avatar
Sure it would help. For me, i'll only run novak gt7s and lrp quantums, they're both excellent.
JusBox is offline   Reply With Quote
Old 02-08-2004, 11:41 PM   #15
Cole Trickle's Avatar
You can get the manual here: SR
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
