Foam Tire Truing - 2 degrees ?
I recently picked up a bunch of 2nd hand foam tires, and they are all trued with a 2 degree taper from inside to outside. The outside being the larger diameter.
Have you guys heard of this before ? and why is it done ?
Craig H.
Craig H.
Re: Foam Tire Truing - 2 degrees ?
Craig H.
Craig H.
I don't see a reason for this on an electric car though, nor have I seen or heard of anyone using it in an electric setup. I'd say that the person you got these from was either going to try it out on a nitro sedan, or just didn't have their truer set correctly when they trued the tires...
