Old 09-17-2009, 02:21 PM   #1
marcel p's Avatar
Send a message via MSN to marcel p
Default protoform ltc on carpet
hey there
dith somebody do some testing with the ltc body on med to high grip carpet.
planing to try it with rubber tires
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 09-17-2009, 02:29 PM   #2
Originally Posted by marcel p View Post
hey there
hoi marcel
i am using it at the weekend at AMCC , i have tried it at groningen inddors and i like the front end feel it gives
the rear is slightly looser then the speed6 but i can control it so i think you can
sidecarphil1 is offline   Reply With Quote
Old 09-17-2009, 02:32 PM   #3
Send a message via AIM to ERTRACHTER
I'm pretty sure alot of people used them at the IIC
ASSOCIATED 12r5.1,REEDY MOTOR AND BATTERY, LRP SPEEDO,KIMBROUGH PRODUCTS,BIG DOG RACING,BELMONT R/C SPEEDSHOP, DENNIS LYMAN RACING, TEAM TOSO, TEAM FACTORY BITTER, SCHUUR SOLUTIONS, SIMMONS RACING, TEAM BOOZCRUZ
ERTRACHTER is offline   Reply With Quote
Old 09-17-2009, 02:40 PM   #4
Johnny Wishbone's Avatar
The LTC works very well rubber on carpet. In med to high traction it may have a little better rotation than the Mazda speed 6.
Old 09-17-2009, 02:49 PM   #5
marcel p's Avatar
great .
thanks for the reply.z
PR racing
Absima /vr racing
Old 09-17-2009, 03:18 PM   #6
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
Send a message via AIM to DENNIS STORTI
I ran the body on the rug with rubber tires it worked awesome
DENNIS STORTI is offline   Reply With Quote
Old 09-17-2009, 03:24 PM   #7
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
They better work I just ordered 3
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 09-17-2009, 03:31 PM   #8
Scottmisfits's Avatar
It sits between the Speed 6 and the R9R. The R9R is super aggressive and twitchy where the Speed 6 is very stable, but still corners, with a slight push. The LTC-R has a great downforce and has plenty of steering while still being very predictable.
A few of our local racers were using the LTC with a J Concepts TC wing and were having great results with it.
Scottmisfits is offline   Reply With Quote
Old 09-17-2009, 03:32 PM   #9
Does the LTC has more steer than the Mazda 6 and mazda speed 6?
I'm looking for a good car body and this moment I like the R9-R.
But I want to try the LTC-R.
Th R9 has a lot of steer.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 09-17-2009, 04:28 PM   #10
artwork's Avatar
Trader Rating: 62 (100%+)
The LTC-r seems to be between the R9R and the speed 6 as far as steering goes. I was running the R9R, but I have now moved to the LTC-r and I really like the change.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 09-17-2009, 05:02 PM   #11
Ok thanks.
I will try the LTC-R.
i use at this moment a Mazda speed 6.
a good body but I like the R9-R more.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 09-17-2009, 05:25 PM   #12
Timmie's Avatar
Ok thanks.
The LTC and R9 are my two favorite bodies to use currently. I like to use the LTC if the track is large and has a lot of high speed sections. It stays planted on long sweepers but still has enough steering to pull the car in tight running at top speed. For smaller technical tracks I prefer the R9 because it rotates so well. Since you like the R9, you will defiantly like the LTC I have 2 of each ready to go at all times hehe
On carpet I prefer the R9 because It has a little more steering in it. But I think the LTC is more forgiving.
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 09-17-2009, 05:32 PM   #13
Ok Thanks.
Than I will keep the R9 for indoor. here I went great with the R9.
The R9 on my home track was a bit nerves but still fast. The LTC will be better here as it is more stable.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 09-17-2009, 07:03 PM   #14
stiltskin's Avatar
Trader Rating: 102 (100%+)
I ran the LTC-R on carpet with in the spring. Better steering than the Mazda or DNA bodies but sacrifices some stability when in side by side collisions. I'm trying out the R9R body right now. I like the R9 but it is upset very easily in tight traffic. I'll be going back to the LTC body when they get them back in stock.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 09-18-2009, 12:23 AM   #15
pcar951's Avatar
Trader Rating: 19 (100%+)
I've found the R9R to work well on carpet if it's mounted a little towards the rear with the wing pushed back. Also found the LTC-R can be made to respond nearly as aggressively as the R9R or as neutral as the Speed 6 depending on mounting and wing position.
pcar951 is offline   Reply With Quote
NEW! PROTOform "LTC-R" Sedan Body daleepp Electric On-Road 131 01-13-2012 10:32 AM
OCRC Onroad Racing rchaulik California Racing 1427 11-16-2009 08:38 PM
Protoform LTC-R PitNamedGordie Electric On-Road 101 01-09-2009 05:40 PM
TC/Onroad Body discussion Davidka Electric On-Road 6 12-01-2008 04:25 PM
