Old 09-17-2009, 01:06 PM   #1
Trader Rating: 17 (100%+)
Default Trying to figure out what pitch my spur gear is
I recently bought a xray T2007, the person I bought from doesn't know what pitch spur gear is on it cause he hadn't used the car in a long time
on the side it says 96, so it has 96 teeth, but I am not sure about the pitch
it looks like 64 cause the teeth are small, but then again I looked at some 48 pitch spurs and they look pretty much the same
can anyone help me with this
maybe I can post a pick of it??
Mike
pantherblack is offline   Reply With Quote
Old 09-17-2009, 01:15 PM   #2
I would guess it is 48 pitch as the XRay gears are rather large and I haven't seen a 64 pitch that small. I would suggest you take it to the local hobby shop and have them look at it and pick up your pinion there.
Cammer is offline   Reply With Quote
Old 09-17-2009, 08:41 PM   #3
Measure the diameter of the spur. 48 and 64 are diametrical pitch meaning #teeth/pitch = diameter. A 64 pitch 96 tooth spur will measure 1.5" diameter. A 48 will measure 2 inch in diameter.
Not sure if the metric spur are the same.
Tuner EM is offline   Reply With Quote
Old 09-23-2009, 09:41 PM   #4
thanks for the replies, it is a 64P spur
Xray T1 David Galdo Electric On-Road 12705 07-04-2016 02:07 AM
Xray T1FK05 Mdoc Electric On-Road 5433 01-31-2010 06:42 AM
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
