Old 09-16-2009, 05:44 PM   #1
JayL's Avatar
Default 9 or 10 pound shock spring?
anyone know of a touring car shock spring that is around 9-10lbs? I found tamiya red at 11lbs but need it softer
JayL is offline   Reply With Quote
Old 09-16-2009, 06:00 PM   #2
mkdut's Avatar
Trader Rating: 19 (100%+)
Losi XXXS Springs
https://www.ssl-stormerhobbies.com/c...ns&pn=LOSA5119
mkdut is offline   Reply With Quote
Old 09-16-2009, 06:21 PM   #3
wingracer's Avatar
Trader Rating: 24 (100%+)
I think Custom Works silvers are 9lbs but they might be a bit long. Also I have a bunch of Silva springs that go from around 11 all the way down to around 6.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-16-2009, 11:08 PM   #4
corallyman's Avatar
Trader Rating: 99 (100%+)
I am pretty sure AE has a TC spring that is like 8 lbs. I think its green.
Nope, I was wrong, its a 12 pounder.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 09-16-2009, 11:55 PM   #5
Universal Spring Chart from thard.co.uk
hope that helps.
Minami is offline   Reply With Quote
Old 09-17-2009, 10:55 AM   #6
JayL's Avatar
Originally Posted by Minami View Post
Had that, not seeing the one 9-10lbs except those wierd tamiya ones I can't find...
will check out the xxx-s thanks
Old 09-17-2009, 11:21 AM   #7
oeoeo327's Avatar
Trader Rating: 74 (100%+)
Losi XXX-S springs will work, but the spring might shift around on the upper and lower spring perches (unless you're using Losi shocks)...
The shock springs that come with the Cyclone S RTR are roughly 8-9 lbs. I have a set that I use from time to time if I need a softer spring.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 09-17-2009, 12:22 PM   #8
Yeti35's Avatar
JRXS has a 10.5 lb spring, that is as low as they go on that car.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 09-17-2009, 12:34 PM   #9
JayL's Avatar
ooh, nice, I may be able to find those local
Old 09-17-2009, 12:36 PM   #10
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Here are the "wierd" Tamiya springs...part # 53333
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 09-17-2009, 01:08 PM   #11
MikeR's Avatar
Trader Rating: 15 (100%+)
HPI/HB SILVER springs are 16lbs. Pretty firm actually. Look at the chart posted earlier as proof.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 09-18-2009, 06:47 AM   #12
oeoeo327's Avatar
Actually, there are 2 silver HPI springs. I think you're referring to the Pro4/Cyclone spring, which is 16.9 lbs. HPI part #6825, on the other hand, is an 8.6 lb. spring. If you search online for "HPI 6825", you'll find several suppliers that have the part in stock...
Old 09-18-2009, 11:54 AM   #13
JayL's Avatar
ah, thank you! now I can stick with Tamiya
CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks John Stranahan Electric On-Road 1776 03-01-2016 01:18 PM
