Old 09-15-2009, 10:44 AM   #1
zonda's Avatar
Default electric set up help !!!!!
im pritty much an electric noob although I have had electric in the past. OK so i have a Ripmax Xtra Quantum electronic speed (pritty sure its used for boats and has a 18t limit) and MTONIKS Big Lix Mach One 15x2 motor and a 1300 mah batt pack. the motor only spins up when there is no load at all ! I mean when i take the pinon off or when the motor is dismounted. I only have to rest my finger on the pinoion and the motor cuts out. My belts are very tight and have a lot of tension and you have to press down on the car to roll it along the floor (when the motor is in also)
p.s I have tried 3 different cans and they all do the same.
can some one please help me. is the speedo just the wrong one ?
zonda is offline   Reply With Quote
Old 09-15-2009, 02:11 PM   #2
zonda's Avatar
ok i manged to get the car going with that batt pack but it hardly has any life. it got hot after driving it round my living room and the car barley moves. I noticed the motor got hot and speedo got hot even though i drove the car round for only 1 minute. any surgestions to what i do. i.e buy new speedo and battery. also im runing 35 tooth pinion is that to much ?
Old 09-15-2009, 08:03 PM   #3
jhwnissan's Avatar
that really sounds like an esc problem.. i had the same thing happen some years ago. unfortunately mine caught fire after too much driving.
Josh Howard on RCNEWB.COM
Drawing rc car body madness in a Bunker....
Rare Losi R/C Belt Maker Extraordinaire
Need belts or parts? I can help.
SWs, RWs, XX-4s, XXX-S
jhwnissan is offline   Reply With Quote
