What Are The Pros And Cons Of Electric Rc Cars?
What Are The Pros And Cons Of Electric Rc Cars? Best On Touring On-Road Cars. Planning To Buy 1 Electric Tamiya TT-01 Any Commends?
Pros:
They aren't as loud as Nitro cars so you can drive them at night or around your local street without disturbing neighbors.
You can recharge the batteries so you don't have to buy fuel
You only need one servo for steering and the speed control is electronic with no moving parts so it's more reliable.
You don't need to adjust carburetor
You don't need a glow starter
You don't need pull start
They are odorless don't have smell of fuel
They have different capacity batteries so you can drive longer without recharge/refuel
Basic kits are cheaper than Nitros
Cons:
They're too quite for some and don't sound like a real engine.
You need special chargers for the battery packs.
Charging takes longer than refueling a tank.
You need stronger/faster more expensive motors/ESC/battery to go as fast as Nitro cars
TT-01 is a good cheap basic touring car chassis with low priced hop ups available from a few manufacturers.
Cons:
Is The TT-01 A Fast Car??? Around What Spd?
The question at hand is what are you planning to do? Are you bashing around your neighborhood or are you going to be doing onroad racing. If your not going to be racing in a Tamiya class race then its not worth it to use the TT01 chasis to race onroad. I speak from experience since I started out with a TT01 and to make it race worthy for on road I had to convert it to the 3racing carbon fiber chasis so I could have more gearing options. The stock chasis is very limited unless you get the TT01R chasis and even that is limited. Here is a pic of my chasis upgraded to the 3racing chasis and running 17.5 brushless. Maybe it might be a good idea to start with an RTR version of the cyclone.
Pros:
quiet
less cost in the long run
no clean up (besides tire shavings)
go faster than nitro counter parts
less of a chance of eating gears
cons:
up front cost (for a good set up to be competitive) will cost more
lipo batteries require care with use (so do nimh to an extent)
short main races
quiet
cons:
short main races
Car is built cheap, limited in its capabilities, and wears excessively. Out of the box they are very slow, and you can't put a very fast motor in them as the gearing options are limited
I was put off just by building the kit, and sold it after a single run. I'd only recommend it as a driveway basher.
speed is relative, even if u have a car that goes '70mph' its boring after 2 or 3 blasts, provided u dont flip it over or hit a pot hole or an explorer's read tire and trash the car.
electrics what hurts is the up front cost
nitro is cheaper in the door, but like a buyer's club they have u and u have to keep spending. whereas in electric many times u dont have to spend any more of significance. any car, u break it, well then u gotta fix it.
R
as i mentioned in another thread, the tt01 isnt really brushless friendly in most instances b/c of its limited gearing option and b/c of the beating its drivetrain would take from hotter motors period. to the gentlemen above with the car in the pic. u prolly have a piece of servo tape naturally under your xponder, but make sure that wire for it doesnt touch that graphite at all. be runnin and all of a sudden the scorer says ur hits are weak or u missed a lap. never cool. just heads up.
R
R
R
I don't agree with the cost issue, The low grade stuff is cheap whether your looking at electric or nitro, the high-end gear is wickedly expensive,for both. It all comes down to what you want to spend.
Personally my preference is for electric for two reasons.
1.Noise-hate the horrible screech of the nitro's.
2.Maintenance, The nitro's simply have far more mechanical parts, and all mechanical parts require maintenance. Keeping an electric car going for a day of races is enough work for me.
And then you will get some people who love the noise and all the mechanical parts....So its more of a preference then a pro/con situation.
It depends on what you want to do with the car. Do you want to race at a local track or do you want to run up and down the street (bash). If you want to bash the car you want will be just as fast as any other 10th scale touring car. If you want to race it may not be a good choice. Go to the local track on race day and see what most are running. Out of the cars you see, find the one that you like and make sure the LHS (local hobby shop) has parts for it.
You can tell really fast what are the most popular cars are on the market just by seeing the most hit post on this forum.
Carbon fiber is also referred to as graphite. Many companies refer to it as graphite. I never heard of graphite/carbon fiber screwing with transponders but it could happen because graphite does cause a lot of electrical problems
Pros Electric cars=
1)When Electric cars are built brand new, they tend to want to sleep on your bedroom pillow.
2)When electric cars do well at the track, they usually like to ride shotgun on the way home.
Pros Nitro cars=
1)It will put some hair on your chest!
R/C car cons=
None found yet.
Pros Nitro cars=
R/C car cons=
None found yet.
