Old 09-14-2009, 12:28 AM   #1
PaPeRo's Avatar
Questions?? Has anyone tried putting a low turn BL motor inside a Tamiya M03/M04/M05 chassis?
I'd like to know what the results were and if the gearbox could handle it without needing a rebuild too often. Reason why I ask because I'll be installing a 3.5T or 4T motor in a M04 chassis. I'll be using an aluminum spur + aluminum ball differential + ceramic balls + hollow carbon gear shafts + full ball bearings.
PaPeRo is offline   Reply With Quote
Old 09-14-2009, 12:44 AM   #2
tony gray's Avatar
Depends how much money you've got to replace gears...
Because this is what's gonna happen within about 5 mins
Has anyone tried putting a low turn BL motor inside a Tamiya M03/M04/M05 chassis?-velo07_01.jpg   Has anyone tried putting a low turn BL motor inside a Tamiya M03/M04/M05 chassis?-velo07_02.jpg   Has anyone tried putting a low turn BL motor inside a Tamiya M03/M04/M05 chassis?-velo07_03.jpg
tony gray is offline   Reply With Quote
Old 09-14-2009, 12:52 AM   #3
razzor's Avatar
yep they dont like too much power.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-14-2009, 12:59 AM   #4
dameetz's Avatar
Actually I ve got good result when I installed Hobbywing EZrun 5.5t system in my M03. I dont know in a long term the gears will melt coz i ve had mine installed for only a few runs, it was crazy fast though.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 09-14-2009, 01:17 AM   #5
PaPeRo's Avatar
Hmm...seems like the gears won't melt but might break due to enormous torque. Maybe I need to lower the punch setting on the ESC to the lowest setting.
Old 09-14-2009, 04:57 AM   #6
we use either the 27 turn purple bull GM motor or the 17.5 turn EZrun set up in our swifts
they are quick and seem to last , i use mine indoors on a small track and it goes like stink
i think with any more power you will rip the little thing in half !!!!!
sidecarphil1 is offline   Reply With Quote
Old 09-14-2009, 05:44 PM   #7
Having a 3.5T motor in most cars will leave you having to replace the gears, diffs etc. quite often, even if they are aluminium, i suppose if you take it easy, depending on what battery you're using it could "work" well. Not too sure on putting it in a Mini though :P
Tamiya TL01
Tamiya TA05 (ish)
Associated B4 3.5r
Limerick91 is offline   Reply With Quote
Old 11-01-2011, 03:24 PM   #8
joe c's Avatar
sorry to bump an old thread, but I didn't want to start a new one for the same thing...
I just acquired an m03-m and am looking for a good motor for it.
I won't be racing in any clubs or at tracks, so no restrictions.
so what's a good brushless setup for these little cars?
RCMT.net
joe c is offline   Reply With Quote
Old 11-01-2011, 03:39 PM   #9
MrChodes's Avatar
In the Australian section of these forums is a thread "Velodrome time" about Minis with low turn motors for Velodrome speed runs.
Serpent S100. Ducati FM1-e bike.
MrChodes is offline   Reply With Quote
