Old 09-14-2009, 11:22 AM   #121
Trader Rating: 18 (100%+)
The fast guys won again! SUPRISE! LOL
While some may have won using "prototype" speed controls, it is nothing that won't be addressed in one way or another in the future. Either with equalized tech or specifically introduced rules to eliminate any "advantage" that someone may have come up with. In the end fast guys with fast equipment won. Slow guys with fast equipment usually end up in the H or I main(like me). LOL
Just a note: Introducing votage to the motor via booster circuitry and "reciever packs" could only be checked in a brushless system via an O-scope. I didn't see one in the pits so how could someone "PROVE" any advantage? Straight speeds are an indication but are not "Proof".
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 09-14-2009, 11:26 AM   #122
Conrad's Avatar
What ever happened to just turning up, having fun and racing?
Conrad is offline   Reply With Quote
Old 09-14-2009, 11:39 AM   #123
jolson88's Avatar
Originally Posted by Wild Cherry View Post
The thing everyone of you guys miss
is...
The beginner racer ....
He's has to deal with all of this and my money is on the fact that all the new blood on-road has destroy will continue to dry up ...
Beginner's are't gona pay for it if they can't be competitive....
Stock ? Spec ?
Gona die ....
Long live the Mod class's.....
As a new guy to on-road, I call bull . The problem is a simple matter of expectations and education. The real issue is a new guy expecting to be competetive out of the gate.
The first thing you have to do is learn to drive well. Second, learn to setup your car/chassis. Only after those two can you expect to be able to use the "latest and greatest" tech. What good does it do to get all the powerful stuff if you can't handle it? All a newbie would end up doing is breaking his stuff faster and then quitting because he just blew a bunch of money and can't/doesn't want to pay for replacement stuff. You can't just drop a bunch of money and be competetive from day one.
There are enough classes now in many on-road programs where there is a really good progression from novice -> amateur/sportsman -> expert. And the best part is that to make it through novice (and much of the way through amateur), you don't actually have to spend all that much money. At those levels, driver/mechanic skills are going to make a much larger difference than money and the latest-and-greatest gear.
As a techie/geek, I personally _love_ the trend of speedos going the route of updateable firmware paired with computer software. I applaud Tekin for their product (definitely a speedo I want to upgrade to when I'm not such a newb), and I hope other companies catch up. In the long haul, competition amongst these companies will greatly benefit us, the racers.
Associated B4
Tamiya TA-05
Traxxas Slash
jolson88 is offline   Reply With Quote
Old 09-14-2009, 11:52 AM   #124
Tech Legend
Wild Cherry's Avatar
jolson ,
hurry up and get that CRC or your gona out luck being the slower car & all ....
O-Wait !
Tekin will fix it soon so they are faster , but then Lrp will throw down their thump card ....
Have fun buying all those speedo's...
talk about Bull ?
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 09-14-2009, 12:02 PM   #125
superspeed's Avatar
spec class and set budget limit $ wise, so people can still run different brand equipments and as long as the cost of running car is less than certain $ amount.
just throwing ideas out there:
$ 200 - novice
$ 500 - intermediate
$ 500 plus - pro /advance...
superspeed is offline   Reply With Quote
Old 09-14-2009, 12:08 PM   #126
jolson88's Avatar
jolson ,
O-Wait !
talk about Bull ?
Nope, there is _zero_ need for me to buy either one of those speedos . Since I primarily have to work on my driving/setup skills right now, I'm just running an older LRP speedo with a Silver Can in novice, and soon-to-be RCGT/"Scale Spec" at the Hangar.
Even if I did bump up to 17.5 stock, I would still not need the top-of-the-line speedo because there would still be a lot of learning I would need to do before I could actually use that power. My personal opinion is that boost/turbo/timing doesn't mean _jack squat_ if you are still hitting the boards every lap (or every couple of laps).
It's not the destination that counts, it's the journey .
Now, if you are already a racing expert, I can see your point . But I was specifically debating your belief of this killling "new blood" in on-road.
P.S. You should know how bad of a driver I am right now after observing my horrendous driving skills are even in off-road racing novice at TRCR .
Associated B4
Tamiya TA-05
Traxxas Slash
Old 09-14-2009, 12:12 PM   #127
Send a message via Skype™ to slotracer577
Just suggesting that if you have a guy that is way faster in a straight line, they get checked out. Extra speed is by no means proof, but I have seen it where the 10th place guy got torn down after he was 2 mph faster than the leader. turns out the bike was a bit bigger than it was supposed to be. Could even be someone swapped a arm or windings into a motor, not a speed control issue.
John
slotracer577 is offline   Reply With Quote
Old 09-14-2009, 12:12 PM   #128
DerekB's Avatar
What the controversy about the ESC was...the RX 7.4 volt pack was wired into the speed control and what people theorized about this was it was feeding 7.4 volts to the motor therefore not fitting into the 3.8 volt 1 Cell lipo.
The ROAR rule is open a bit for interpretation, which is how things advance. It's legal for the ESC to power the RX, but at the end says "for only this purpose" if the RX pack was giving voltage to the motor it sort of would be illegal.
It's impossible to tech...to see if it was that they could have just ran the RX battery into the RX.....BUT
I wouldn't have done it either because there are no real rules...loop hole.
DerekB is offline   Reply With Quote
Old 09-14-2009, 12:26 PM   #129
Trader Rating: 38 (100%+)
Sounds like this has nothing whatsoever to do with "prototype" ESCs and more to do with fixing a potential loop hole in the rules.
or8ital is offline   Reply With Quote
Old 09-14-2009, 12:43 PM   #130
DerekB's Avatar
To be fair, we don't know if they figured something out with the lower voltage before somebody else did. Software is a powerful tool.
Old 09-14-2009, 12:44 PM   #131
So the ESC in question with the power source is also the ESC that was uber fast in the 3.7v classes? Was anyone running that ESC in the 7.4v classes? Was it fast there?
Old 09-14-2009, 12:57 PM   #132
Trader Rating: 16 (94%+)
Correct, this speedo was providing laptimes at least .3 to .5 seconds quicker per lap in a capable drivers hands, and 10-20 feet to anyone using it down the backstraight regardless of driving skill.
Not aware of any being used in Sedan with 7.4v LiPo's.
kn7671 is offline   Reply With Quote
Old 09-14-2009, 01:02 PM   #133
artwork's Avatar
Trader Rating: 62 (100%+)
The drama that surrounded the new speed control at IIC was almost shocking. You had people running over taking pictures while the CRC team was out at lunch and stuff. When no one was around the other manufactures were searching for some way to DQ the new speedo...In a word it was pathetic.
There are currently no rules that govern the ESC's but I assume their will be soon. The rules do not cover software updates that might have new profiles that no one else can get. It does not cover the amount of timing advance, or any of the other new features. Simply the rules are not specific enough to control this very slippery slope that we are on. How can anyone possibly tech the code that is being pushed to the Tekin...who the hell knows what those guys are doing. Same goes for the KO or anything can can be upgraded at any time and by any person. Without a way to tech software all bets are off. This is a game changer, wanna fix it? Put a rule in that does not allow customer/team upgradeable devices to be used. Yeah, I am sure this wont happen either. The governing bodies and race directors have some work to do around this issue, glad I just race.
The thing that pisses me off...was how good the new CRC car was...and the guys driving them. Everyone is spending all of this time talking about the speedo, but honestly the CRC team was well prepared and brought a great group of drivers. The new car was great and preformed well from stock up to modified (you would think I was on the team). Give credit where credit it due!
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 09-14-2009, 01:21 PM   #134
Found the close-ups of it. Neat looking speedo!
http://rc50.com/modules/coppermine/a...9/picta162.jpg
http://rc50.com/modules/coppermine/a...9/picta164.jpg
http://rc50.com/modules/coppermine/a...9/PICTA296.jpg
Old 09-14-2009, 01:22 PM   #135
robk's Avatar
Trader Rating: 22 (100%+)
A huge horsepower advantage to an already fast group is going to make a big difference. If they did not already have their act together, the extra HP would not matter anyway.
I think things are going to hit diminishing returns pretty soon, but Tekin has the advantage since they just reprogram the speedo basically at will. The big advantage with the turbo feature is that the car runs normally in the infield, and wicks up on the straights, so you keep the motor at a good temp. You can't over time the motor beyond what will make it cog and/or over heat, but if you can max out the timing where you need it (the straights) while still retaining the punch, game over.
