Old 09-12-2009, 10:56 AM   #1
Default Need parts for an old RC12
Hello, I have a very old model of an associated RC12. My coworker suspects that it is from the 80's.
The Differential gears in the rear and the rear axle are in bad condition.
Does anyone know where I can get those parts for this car?
asweeba is offline   Reply With Quote
Old 09-12-2009, 11:06 AM   #2
corallyman's Avatar
Trader Rating: 99 (100%+)
Can you post pictures of the stuff that you have including the parts you need replacing. Most likely if its from the eighties, the only way to get parts is to buy used parts. The car has been discontinued for more than 20 years. I am an oldtime racer, and I may have some parts so let me know what you need. Someone here may be your best chance.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 09-12-2009, 11:24 AM   #3
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Try this hobby shop, they have shipping containers FULL of ancient stuff. I recently found a Delta independent front suspension for the car you mentioned, the original RC12L.
Jackson Hobby Shop
2275 W County Line Rd
Jackson,NJ08527
(732) 364-3334
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 09-12-2009, 05:32 PM   #4
corallyman's Avatar
Jackson Hobby Shop
Jackson,NJ08527
(732) 364-3334
Any chance they have an old mono shock front end from associated?
Steve
Old 09-12-2009, 10:33 PM   #5
ya
racer1991 is offline   Reply With Quote
Old 09-12-2009, 10:34 PM   #6
oh word
Old 09-12-2009, 11:20 PM   #7
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
have you tried the b/s/t section?
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 09-13-2009, 03:30 AM   #8
volracer's Avatar
Send a message via ICQ to volracer
Differential gears? Every Associated RC12 I have every seen or owned had a ball disferential in it unless someone replaced it with a gear differential. You might contact Associated directly for a new axle or diffferential. The axles for all of the early 12 scales were mostly interchangable up until the designers started centering the motor in the pod.
Early RC12 diff gears sortof floated on the axle, later ones had an uflanged bearing like the TRC axle.
If you do have little gears in your larger diff gear, it is more than likely a a DELTA design. I have not seen thier parts for 12th scale in years. I would replace it with a ball diff axle and gear; much easier to maintian.
volracer is offline   Reply With Quote
Old 09-13-2009, 01:17 PM   #9
corallyman's Avatar
Actually the AE RC12E had a solid steel axle with 2 set screw type hubs on it on both ends of it, there was no diff yet.
But I am not sure this has anything to do with what help he needs.
Steve
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Beware of Afroman and Kdeezee P2 Buyer/Seller dispute and Feedback discussion forum 107 04-07-2004 09:49 PM
Tags
parts, rc12
