Old 09-11-2009, 07:39 PM   #1
62 bugzilla's Avatar
Trader Rating: 73 (100%+)
Default gearing for t5r with 3.5 bl ?
I have a tc5r I just got from a freind and I'm putting a 3.5 bl in it for some fun speed runs and I need to know about gearing. I read that 64p gear were allittle smoother and more contact area and it's what came on it as far as a spur goes so I picked up some pinions for it and wanted to get some spurs for it next. I bought a 22 t thru 26 t 64p pinions and the car had a 84 tooth spur but when I went to mount the motor I relized that they wont touch even slid over all the way so I either need way bigger pinions or larger spur so since I have a bunch of new spurs I was hoping a range of spurs to get that would work with them. I'm going to end up racing it with a 13.5 bl and just playing around with it with the 3.5 so point me in the right direction if you would. Also what is the gear reduction in the pulleys of a t5r so I can figure out fdr? Thanks for your help.
62 bugzilla is offline   Reply With Quote
Old 09-12-2009, 02:23 PM   #2
Default help
No body can help me? I think it's around a 105t spur?
Old 09-12-2009, 07:42 PM   #3
Default wow
Wow all these people in this section and no one has the time to help me with a quick suggestion? WOW I've tried to help many on here about things I know about well good for me I guess.
Old 09-12-2009, 08:17 PM   #4
revo61's Avatar
Trader Rating: 18 (95%+)
I did not know AE had come out with the t5, I only heard of a prototype. A 3.5 would be quite a handfull in a 2wd truck.
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 09-12-2009, 08:32 PM   #5
Default sorry
Sorry I meant tc5r and I fixed it in the thread.
Old 09-12-2009, 08:44 PM   #6
revo61's Avatar
You will get more answers if you post this in the TC5 thread, but I think 9-10 fdr will get you in the ballpark. It varies depending on track conditions.
http://www.rctech.net/forum/electric...iated-tc5.html
Old 09-12-2009, 08:46 PM   #7
Trader Rating: 62 (100%+)
try gearing it high 9's to 10.5 check motor temp after a couple minutes. internal ratio is 2.0
The Wease is offline   Reply With Quote
Old 09-12-2009, 08:49 PM   #8
double post
