Ceramic Bearings >
Ceramic Bearings
Ceramic Bearings
Old 02-01-2004, 06:02 AM
OHBRAD's Avatar
Trader Rating: 19 (100%+)
Default Ceramic Bearings
Hi Guys,
I have just ordered in a full set of Ceramic bearings for my Yokomo SD.
With my other type of bearings, the first thing i did when i got them was to take the seals off them and clean all the packed grease in them, and replace with a lighter oil.
What i want to know from you guys who have fitted them is, do i need to take the seals off and do the same thing, i have heard many conflicting stories, i just want to hear what everyone is doing.
regards brad p
OHBRAD is offline
Old 02-01-2004, 08:56 AM
Matt Howard's Avatar
I've used the Acer ceramics and I just took them out of the package and put them into my car. The lube they use is very thin and they spin super right away. I don't have any experience with the Yokomo ones yet though. I can't see why they would put a heavy grease in them though, see what they feel like and go from there.
Matt Howard is offline
Old 02-01-2004, 10:22 AM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I'd spray them out and use a very light oil, propably lighter than what they put in them... but I'm just anal about a free spinning drivetrain.
Randy Caster is offline
Old 02-01-2004, 10:30 AM
Corey Bernardo's Avatar
Blow them out with motor spary...... Then put them on something of same circumferance, so you can spin them and oil at the same time. I use a reamer, for the bearing to seat in, and just spin it.
Corey Bernardo is offline
Old 02-01-2004, 10:36 AM
Trader Rating: 16 (100%+)
Matt,
Using other than ceramic bearings, I was advised to replace them every year after the carpet season ends. Do you have any set standard for when its time to replace ceramic bearings?
FYI...I have a set of $60 polymide (?) bearings from Acer in one XXX-S and a $20 steel set in my other XXX-S. Many thanks.
Still Bill is offline
Old 02-01-2004, 12:41 PM
Originally posted by XXX-S Bill
Matt,
I'm going to run my ceramics as long as I can considering the money they cost. Whenever they don't spin freely anymore would be the time to replace them
Old 02-01-2004, 01:36 PM
Super Moderator
Grizzbob's Avatar
Yeah, I'd just run them until they get sloppy or start to bind or feel odd(even when cleaned & oiled).....
Grizzbob is offline
Old 02-02-2004, 04:46 AM
OHBRAD's Avatar
Default any more
anymore info guys would be aprreciated they should be here tomorrow
OHBRAD is offline
