Old 09-08-2009, 02:23 PM   #1
KinKin's Avatar
Talking Helping gearing up or down????
I have a T1 with 112 spur gear and I just brought 30 tooth pinion gear. It runs very smooth. The motor just warm after 5 min run, but the ESC is a little hot, it is a LRP Comp with no heart sink. Should I gear down the tooth or UP? I want to get a little more trough. Can anyone help? Thanks in advance.
KinKin is offline   Reply With Quote
Old 09-08-2009, 07:11 PM   #2
KinKin's Avatar
Thumbs up still need help for slect pinion gear.
I ran it again on my break time. It get hotter in the afternoon. does anyone know if 112 tooth spur gear what pinion gear should I use? Is 30 tooth is too big for it. Thanks for your reply.
Old 09-08-2009, 07:34 PM   #3
RFALLON's Avatar
Send a message via AIM to RFALLON
Try a smaller pinion. Did you say you do have a heatsink on?
XRAY T2'009
Nexus Racing
KO PROPO
Novak
JR racing
RFALLON is offline   Reply With Quote
Old 09-08-2009, 07:48 PM   #4
KinKin's Avatar
Thumbs up
I don't have the heat sink on it. If i pick up a 20 tooth pinion. will it be too small and will i loos a lot of low end. Thanks.
Old 09-08-2009, 07:49 PM   #5
RFALLON's Avatar
well try putting a heatsink or a fan on first. And when you change the pinion go 1 or 2 teeth at a time. not 10
XRAY T2'009
Nexus Racing
KO PROPO
Novak
JR racing
Old 09-09-2009, 07:22 AM   #6
Try www.gearchart.com
Tiger72 is offline   Reply With Quote
Old 09-15-2009, 01:23 PM   #7
KinKin's Avatar
Smile updated
I down size to 26 tooth. It low the heat little. I check it and it is 110 to 120 degree. Anyone think this is too hot for the Ecs. what is that mean 7.08 ratio? Thank for reply
Old 09-15-2009, 02:01 PM   #8
amnesia's Avatar
I always thought that if the motor was hot and ESC cool then you were running too low a FDR, if the ESC is hot and the motor cool then you need to gear up as you're over-revving the motor.
If this is right then you need a bigger pinion, not a smaller one.
If I am talking @rse, please ignore me
Daniel.
.-= T.O.P. Photon =-.
Titanium Racing (Team TR Driver) / Tekin RS Pro / Novak Ballistic 13.5t / Spektrum
www.titaniumracing.com
amnesia is offline   Reply With Quote
Old 09-15-2009, 02:30 PM   #9
KinKin's Avatar
Thumbs up Thanks
Thanks. What about motor and ECS has the same tempura, When I run 26 tooth and 122 spur gear, But If I run 30tooth with the same spur ECS will be very hot and motor is just hot not as hot as the ECS. This is without heat sinks and fan on the ECS. I want to keep the tempura low before adding a fan. Thanks again.
Old 09-15-2009, 03:58 PM   #10
QUOTE=KinKin;6317368]I have a T1 with 112 spur gear and I just brought 30 tooth pinion gear. It runs very smooth. The motor just warm after 5 min run, but the ESC is a little hot, it is a LRP Comp with no heart sink. Should I gear down the tooth or UP? I want to get a little more trough. Can anyone help? Thanks in advance.[/QUOTE]
what battery are you running
racerguy13 is offline   Reply With Quote
Old 09-15-2009, 06:00 PM   #11
KinKin's Avatar
Smile
Team orion 3600mah 25c and it will get hot faster. I also have 20c battery and get heat slower.
Old 09-20-2009, 09:07 PM   #12
Trader Rating: 21 (100%+)
Ok i want my tempura hot; but my motor cool ...just kidding, but this is really funny....
xxx123 is offline   Reply With Quote
Seberang Jaya RC Track xrays Malaysian R/C Racers 5472 11-19-2016 11:15 PM
UK Race Talk TryHard Racing Forum 9876 12-05-2010 11:46 AM
LRP SPHERE COMP. ESC (80700) Miu Miu Electric On-Road 725 07-08-2010 04:42 PM
Just got off phone with HPI in regads to Savage Flux Lipo's, gears, NIMH and diffs Freezebyte Monster Trucks 50 09-28-2009 01:04 PM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 08:35 AM
The New Malta Guys Race Chat 10malta Malta R/C Racers 679 11-15-2004 09:19 PM
