Need material for sponge tires
Hi all, I`m new to this forum.
Does anybody know where I can get sponge material for tires (the same one that is used for making 1/10, 1/18 car wheels. I have a lathe so shape isnt that important as long the piece is big enough for making tire. I would like to make tires approx 30-32 mm dia , inner dia 20 and 20mm wide. I need this for Losi Micro-t for which I cant get decent tires. I was using bicycle handles but they are too soft and need something harder Any help will be greatly appreciated |
http://www.mcmaster.com/#foam/=3j4u9r
You need to buy the right thickness's and then glue the layers together to create the proper width. Then use a hotwire, or a waterjet to cut out the donuts. Once you have made the donuts, you mount them on the rim, and use a tire truer to bring them to the proper diameter. Good foam is expensive, so make sure you are ordering the right type of foam. Shawn. |
I dont believe this. You know how long I have been searching for something like that? Ages...
Thanks million times mate, you saved my life :D:D:D:D:D:D:D:D |
Any other similar site in Europe by chance? Unfortunately Mcmaster dont ship to Slovenia :cry:
Why not buy premounted?
http://www.losi.com/Products/Feature...rodId=LOSB1144 |
Those are for mini-t, not micro-t....
Originally Posted by mtc777
(Post 6353424)
| All times are GMT -7. It is currently 06:33 PM. |
