Pro 10: 235mm Le Mans Prototype Pan Car Discussion >
Like Tree1606Likes
Old 06-10-2024, 02:56 AM
  #6001
DirkW's Avatar
Looks like a spool axle for 1/12th scale to me...
Pro10noob and LonnyJ1950 like this.
DirkW is offline
Old 06-10-2024, 11:44 AM
  #6002
LonnyJ1950's Avatar
Yes it is.
LonnyJ1950 is offline
Old 06-11-2024, 05:34 PM
  #6003
1spunspur's Avatar
Originally Posted by Pro10noob
That looks like a 1:12 axle, as Pro10 cars have 4 holes for the wheels and your missing some vital parts like the inside dif hub
regards Roy
this bolt pattern fits directly to the spur gear. The hub where the wheel mounts to is on the other side(right side hub). I think the right side hub needs to be of the clamp on style to accommodate this setup. These are currently out of stock.
1spunspur is offline
Old 06-11-2024, 05:46 PM
  #6004
1spunspur's Avatar
Originally Posted by LonnyJ1950
Here's how it goes: install diff ring on axle, be sure it sits flush with disc on axle. Insert diff balls in gear. I usually lube the balls first, but that is a personal preference. Place a ball bearing in the gear's center hole, I use an unflanged bearing here, but again personal preference. Lube the diff ring with your diff lube, lots of choices here, I use a high pressure grease that I can't find anymore, not sure what I'll change to when I run out. Slide the gear on the axle. Be careful not to get grease on the threaded part of the axle. Install a flanged bearing in your diff hub. Now install the remaining diff ring on your hub, a dab of grease on the back side will help stick it to the hub and make it easier to assemble. Again be sure the ring sits flush against the face of the hub. Lube this ring. Slide the hub on the axle. Install a flanged bearing in the outer hub opening. Now, if you press the hub lightly into the gear while holding the axle, it should turn smoothly with just a slight resistance from the diff lube. The next step can vary. Most people use the diff cone, the tapered spacer, next. Place it on the axle with the small end against the hub bearing. Place one or two bellevue, or cupped, washers in the large end of the diff cone, cupped side in. Thread the nut onto the axle and tighten until all the play is removed. Rotate again to be sure it is still smooth. If not try replacing the bearing in the outside of the hub. Put the axle in the car. Place the left hub, usually a clamping hub to keep from damaging the axle, on the end of the axle. Install tires on both sides. Measure from the chassis centerline to the outside of the right or diffside tire. Now measure the same distance on the left side. They should be equal. If not add spacers to the shorter side to make them equal. Now measure from the outside of one tire to the outside of the other. This is normally 235mm. Add spacers equally to both sides until it is. Narrowing the rear track from 235mm is a fine tuning tool for handling, but most people go as wide as possible. Now hold a tire in each hand and try to turn the gear. Gradually tighten the diff nut until you can no longer turn the gear with your thumb. You're ready to test it on the track. Slightly tightening or loosening the diff is also a tuning tool, but these adjustments should be small. If you skip down to page 18 of this PDF there are pictures of this assembly starting with step 55.
http://oldrc.com/TrinityFiles/Evolution10FManual.pdf
Thanks Lonnyj1950 , these are excellent instructions for a standard slipper diff but that is not what I was looking for.
Old 06-11-2024, 10:14 PM
  #6005
Pro10noob's Avatar
You mean this one??---> https://muddslidemotorsports.com/23spax2.html
That is indeed a spool axle
Didn't know they used them at all in Pro10 cars
This is probably the other parts---> https://www.muddslidemotorsports.com/1spsp2.html
Regards Roy
Pro10noob is offline
Old 06-12-2024, 07:15 AM
  #6006
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
we have Fenix ball diffs available here -- https://www.sidepieceracing.com/DGD-235-48-MK3 -- if you're having trouble sorting out the parts from Muddslide
hanulec is offline
Old 06-12-2024, 08:09 AM
  #6007
bsmooth's Avatar
Trader Rating: 18 (100%+)
Default new carpet track in NorCal
So after a 12 year absence, i'm thinking of dusting off my CRC Genx 10LE. It appears the 235mm conversion kit is disco'd on CRC's website. Is there anybody else that makes a conversion kit for this car?
Thanks,
Steve
bsmooth is offline
Old 06-13-2024, 12:45 AM
  #6008
1spunspur's Avatar
Thanks hanulec
Old 06-20-2024, 12:39 AM
  #6009
MonkeyCmonkeyDo's Avatar
My calipers at home crapped out on me and are all buggy but I will get that tire Dia. Lol.
d
MonkeyCmonkeyDo is offline
Old 06-25-2024, 10:43 PM
  #6010
57.4mm?
I measured with the 100thou side of a machinist scale and took it to mcgoogle.
D
Old 07-10-2024, 07:23 AM
  #6011
JeepPower's Avatar
Originally Posted by MonkeyCmonkeyDo
57.4mm?
D
Use this - https://www.tqrcracing.com/rc_tools/rollout.asp
Also can get one for the phone-- I use RC GearCalc -- it's on Google Play. Quite handy on raceday
Taz_S and LonnyJ1950 like this.
JeepPower is offline
Old 07-17-2024, 03:47 AM
  #6012
Restomod
Taz_S, TOADYY, foampervert and 6 others like this.
billtc3 is offline
Old Today, 06:13 AM
  #6013
JeepPower's Avatar
I called CRC last night. Their new #1813 235mm chassis currently comes with their widening kit (uses the 200MM rear axle), but apparently they are working on developing a true 235mm rear axle for it.
Attached Thumbnails Pro 10: 235mm Le Mans Prototype Pan Car Discussion-3937598000004776301-scaled.jpg
nik77356 and MonkeyCmonkeyDo like this.
Old Today, 08:55 AM
  #6014
RCW
Trader Rating: 29 (100%+)
I have been running the CRC car on asphalt this summer with the adapters, it has been very competitive! Running against Xray, Fenix, and Roche, and have finished on the podium almost every race. A true 235 axle would be nice, but certainly not nessasary!
RCW is offline
Old Today, 01:13 PM
  #6015
Need this side braces if I get this to update my chassis. I really like the roche or fennix options.
in do time.
D
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
