Pro 10: 235mm Le Mans Prototype Pan Car Discussion >
Like Tree1079Likes
Old 05-04-2020, 11:54 AM
  #5476
TOADYY's Avatar
Originally Posted by ptrhahn View Post
What are you guys using for asphalt tire sauce/traction compound?
I have some, uh, vintage Trinity Red Dot, but I don't how good it is any more.
You can use almost any tire sauce which is available to you, i.e. Paragon, SXT, Jack the Gripper and etc.
I will usually add 30-SPF suntan lotion after applying tire sauce, which make the traction will last longer for asphalt.
ptrhahn likes this.
TOADYY is offline
Old 05-04-2020, 03:07 PM
  #5477
daleburr's Avatar
Depends on the tyre. A Jap tyre like UFRA works best with Spider Red or MR33v3 (they're both the same).
Most other tyres work best with CS High or Speedtech.
The best additives are all thin oily additives that soak into the foam easily.
daleburr is offline
Old 05-04-2020, 03:49 PM
  #5478
Pro10noob's Avatar
Running Spider red and Speedtech and if it is really hot, Corally TC5.
Still got me some bottles.
Running BSR and GP-Speed tires
Regards Roy
Pro10noob is offline
Old 05-18-2020, 09:11 PM
  #5479
LonnyJ1950's Avatar
Originally Posted by Azsmartbet View Post
The track I love in Mesa, AZ is starting to a grow a pro 10 class. We decided on 2s and 10.5 motor. The car I chose is Fenix - not sure I love it based on the build and instructions but I do really like the car and handling. I just started this Saturday and a vid is below.
I have a neat little page I found online for tips and tricks on my 1/12. Does anyone have a 235mm pro ten tips and tricks one pager?
thanks! Darn vid is too long I’ll try to upload to photobucket.
Planning on being in Mesa to race next Sat. Are you running 10.5 blinky or boosted?
LonnyJ1950 is offline
Old 05-22-2020, 06:47 PM
  #5480
ScottE1776's Avatar
They run 10.5 blinky
ScottE1776 is offline
Old Yesterday, 02:43 PM
  #5481
bigl's Avatar
Trader Rating: 39 (100%+)
Hi guys I used to run pro10 back in the early 90ís and Iím interested in getting back into it I currently run 1/10 off-road so Iím up to date on most stuff but I have a few questions and I thought I would ask here
1. Are you guys truing tires for asphalt?
2. What brand and compounds are most popular for asphalt?
3. Where is a good place to get tires
4. Can I run a standard servo?
5. Whatís the difference between v-link and pivot link?
thanks in advance ant info is greatly appreciated
bigl is offline
Old Yesterday, 03:00 PM
  #5482
LonnyJ1950's Avatar
Can anybody running 10.5 blinky tell me approx how much battery you use in a run. Our track is pretty open.
Old Yesterday, 03:37 PM
  #5483
TOADYY's Avatar
That can depend on big the track is. When I run at Steel City which has approx. 225' straight, I use a 5000mAH battery and have about 40-30% left. A 4000mAH will not finish 5min.
LonnyJ1950 likes this.
TOADYY is offline
Old Yesterday, 03:53 PM
  #5484
TOADYY's Avatar
3. Where is a good place to get tires.
1. Can depend on the conditions. Team purple (F), Pink (R), Orange (R)
2. BSR and Contact
3. BSR directly
4. That depends on the car. Typically Futaba S9650
5. I will let someone else explain this in detail.
TOADYY is offline
Old Yesterday, 04:20 PM
  #5485
LonnyJ1950's Avatar
Originally Posted by jetnjme View Post
The long awaited "Litesabre" will be available Feb 1st...
Litesabre Pro10 Chassis Kit
Anybody running one of these?
Old Yesterday, 04:30 PM
  #5486
ScottE1776's Avatar
was tempted but haven't pulled the trigger yet.
Old Yesterday, 04:49 PM
  #5487
Airwave's Avatar
5 is quite easy if you know what importance the roll center has in pancars and where it is located. Basically, with a pivot ,the roll-center is in the pivot, with a v-link, the roll-center can be under the car or deep in the ground.
Airwave is offline
Old Yesterday, 09:30 PM
  #5488
bigl's Avatar
is on favored over the other for asphalt?
bigl is offline
Old Yesterday, 10:18 PM
  #5489
Moderator
Pro ten Holland's Avatar
Just to add a few notes to the above.
For the questions on tires: I run GP speed tires, 36 shore rear, with 38 shore fronts (HF38 compound). This works pretty much everywhere, except for dusty conditions.
I start my tires on 58mm diameter. I found that I was actually able to get more usefull lifetime out of the tires this way.
On the differences between a v-link and a traditional link style rear Suspension: for me, the v-link provides more mechanical traction on the rear.
The v-link helps me in low traction conditions. But when traction picks up, I found that both systems can work equally well.
Pro10noob likes this.
Pro ten Holland is offline
Old Yesterday, 10:26 PM
  #5490
Moderator
On the question of battery capacity needed for 2s 10.5t, I run shorty batteries (5800, 6000 mah).
This is actually a compromise situation. My car handles better with a shorty battery, but in high traction conditions I have to be careful with runtime.
Pro10noob and LonnyJ1950 like this.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
