Pro 10: 235mm Le Mans Prototype Pan Car Discussion >
Like Tree872Likes
Old 11-07-2018, 06:04 PM
  #5056
Hi guys
I own an old RC10L3, narrow (190mm?)
I have it set up with a brushless and a pair of lipo saddles.
Is there a basic setup for asphalt with low grip (racetrack but not very good asphalt)
Basic questions: Setup sheet appreciated too ...
Which tire hardness should i use?
Should I use side springs on shocks? or just oil to damp it?
What about the center shock spring and oil?
Im completely lost here, since i have no other pro10 running around...
nuno
enzyme is offline
Old 11-08-2018, 05:24 AM
  #5057
Airwave's Avatar
From what I remember, RC10L3 is a T-based car. So it means the the torsion springs hardness is replacedby the stiffness of the T, and the lateral dampers are replaced by the greased pod.
Airwave is offline
Old 11-08-2018, 07:05 AM
  #5058
1/8 IC Fan's Avatar
Trader Rating: 76 (99%+)
Correct, yet, they had two cars, one oval and one "Touring".
The Oval has the standard friction disc, and the Touring has the shocks.
Irrgang used to make various t-bars. Check with Mcpappy too, they may have something to fit the bill. http://www.mcpappyracing.com/store/c...52dPlate-Parts
1/8 IC Fan is offline
Old 11-09-2018, 03:48 AM
  #5059
Originally Posted by enzyme View Post
Hi guys
nuno
Although for a 235mm car, this may have some handy info - http://site.petitrc.com/Tech/AE_RC10...on/Aritcle.htm
Scott_T is offline
Old 11-09-2018, 08:09 AM
  #5060
So, trying to modernize with some updated components. A 5500 shorty lipo, XR10 (which is astonishingly small) and 10.5T brushless motor. Unfortunately with the later, there's zero adjustment in the ground effects rear bod. I'm not sure why, but it seems like it's down to the holes being in different places compared to old motors. I'll try reverting to a more standard 10L pod. With that, I may put the triple shock setup back on... the sway bar is kind of a mess with all the additional wiring that has to go to the motor. I decided to go back to standard Ti turnbuckles instead of the Corally steering linkage, as the latter had a lot of play in it.
I assume I'll be OK for testing purposes with old school Radio/Receiver?
ptrhahn is offline
Old 11-09-2018, 10:06 AM
  #5061
1/8 IC Fan's Avatar
I am not sure, given that these days servos (digital) require a newer (modern) radio to work correctly, I am not sure with an ESC, Also I am not sure if the AM Frequency of the Receiver will be affected by either the motor or the ESC itself? I know when I used a Digital servo in my older FM / PCM radios they seemed to become noisy and not work as they would in a 2.4Ghz radio system.
One of our electrical gurus may chime in.
Old 11-09-2018, 10:34 AM
  #5062
If it matters, it's an old servo too. The ESC seemed to supply voltage for a variety of applications, but I didn't even think about motor noise.
ptrhahn is offline
Old 11-09-2018, 10:51 AM
  #5063
1/8 IC Fan's Avatar
But the ESC receives an input signal from the Receiver, and I am not 100% if the older receivers are able to send the signal as required... Like I said maybe one of the Electronics gurus may chime in.
Old 11-09-2018, 12:45 PM
  #5064
Pretty sure the servo signal is standardized except for a few of the newer high end radios (px7, etc.). I think it is an analog signal as well, so the old radio should work fine except for some of the newer servos. I know I have read analysis that says the limit for latency is now the servo protocol and that is why Futaba did the sbus system on the px7. It allows them to run a different control signal that has the potential to have less latency.
ptrhahn likes this.
slotracer577 is offline
Old 11-09-2018, 01:27 PM
  #5065
Cool. I found some other threads that back that up as well. So I'm some sort of artful battery mounting scheme away from firing this thing up.
ptrhahn is offline
Old 11-13-2018, 06:44 AM
  #5066
Made a little progress with a Liop and triple shock retrofit with a 10L using stuff I had laying around, turned out pretty decent and gives me a wider base on which to mount the body. Whole loaded chassis without body weighs 909g
ptrhahn is offline
Old 11-14-2018, 02:41 PM
  #5067
Last round of PRO10 Catalumya:
Taz_S, Leester, LonnyJ1950 and 1 others like this.
TyoBBS is offline
Old 11-26-2018, 12:02 AM
  #5068
Josh-n-ya's Avatar
Trader Rating: 81 (100%+)
Those of you who have tried the Fenix gear diffs in your pro10s what oil did you use in them??
Josh-n-ya is offline
Old 11-26-2018, 07:02 AM
  #5069
Another question for you guys: I'm accepting that if I ever want to race the Pro10 again, I'm going to need to race something else too, to redevelop driving skill. I just wouldn't be comfortable showing up at a national Pro10 event having only driven it around my neighborhood or something after 20 years. I need practice, and there is no local Pro10 racing... I'd need to go to nationals, or to steel city when I'm in LA.
My choices are 1/12 scale or F1. 1/12 seems more like Pro10... the LeMans body and foam tires. F1 is 1/10 scale pan and 2S batteries, but they typically run on rubber tires and the aero is different. Thoughts? I'm leaning to 1/12 scale.
ptrhahn is offline
Old 11-26-2018, 07:42 AM
  #5070
1/12 scale is more like pro10. I also run gtr, but it's not nearly as precise as 1/12 or pro 10. The rubber tires just don't carve a corner like foam. They also don't handle better with speed to make the body work like a 1/12 or pro10.
