Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#4246
#4248
Dale upper link is as you say on a pan car. I think the camber gain change is the biggest component.
For exit steering try less rear droop.
#4249
Made a few changes, and we had a nice warm day here in the UK so ideal for another run.
Initially tried:
- Less reactive castor
- More castor (7deg)
- New diff balls
It felt a little better, but still short of traction. I then tried:
- More angle on the main shock (nose down).
- Diff backed off
- Less punch on ESC
That was a decent improvement, the car now feels nice throughout the lap. I'll probably go a bit more in this direction, (e.g. thinner oil, softer spring) as more traction will always help at this track.
Video here:
https://youtu.be/foLCc_1F0KY
It's a touch unstable on the straight, but the front wheels are almost parallel, so some toe-out should sort that.
Thanks for the tips and hints
Initially tried:
- New diff balls
- Diff backed off
- Less punch on ESC
Video here:
#4250
Initially tried:
- New diff balls
- Diff backed off
- Less punch on ESC
Video here:
Initially tried:
- New diff balls
- Diff backed off
- Less punch on ESC
Video here:
Try it out, it's likely the easiest change to make.
#4251
Just saw these from Protoform (credit CompetitionX) - new 235mm from Protoform. . .looks sexy as heck!!!
New Bodies from Protoform - AMR-12 PRO-Lite and the Swift -235 Pro-10
#4252
That was released last September. What they just released was a .030 regular weight version of the body.
#4253
ahhhhh, well, that was too far back! LOL - I hardly remember what happened last week!
#4254
Trader Rating: 89 (100%+)
Ride height
What is a good ride height on smooth asphalt ?
#4256
Ride height
Hi Roy ,
Would it be ok to start the front height at 6 and the rear at 5.5 ?
Advance thx,
John
Advance thx,
John
#4257
Reverse that, Front 5.5 and rear at 6
#4259
Yes - from experience, NEVER run a forward rake (rear higher than front) . . . straaaaaange behaviors occur then. . .
#4260
Initially tried:
- New diff balls
- Diff backed off
- Less punch on ESC
Video here:
Initially tried:
- New diff balls
- Diff backed off
- Less punch on ESC
Video here:
We still race F1 wide foam on asphalt here. It is similar to your pro ten style cars. There has been a breakthrough in foam tyre technology in the last few years - I'm not sure if you can get something equivalent for pro10, but the Kawada P rubber, Zen Omega or maybe TRG TZ tyres, seem to be a step up on other foam we have tried outdoors on asphalt (we don't use traction compound)
