Pro 10: 235mm Le Mans Prototype Pan Car Discussion >
Like Tree783Likes
Old 01-26-2016, 10:57 AM
  #2641
Moderator
Pro ten Holland's Avatar
Looks killer roy!
Let us know how it goes
Pro ten Holland is offline
Old 01-26-2016, 11:16 AM
  #2642
Pro10noob's Avatar
Thanks and i will.
Regards Roy
Originally Posted by Pro ten Holland View Post
Looks killer roy!
Pro10noob is offline
Old 01-26-2016, 11:33 AM
  #2643
Wazza22's Avatar
Trader Rating: 27 (100%+)
Good luck Roy, The shell looks great!
Cheers
Wazza22 is offline
Old 01-26-2016, 12:17 PM
  #2644
Joost K.'s Avatar
Good luck matey... Get some tight lines over there and bring back helpful info...
Joost K. is offline
Old 01-26-2016, 12:47 PM
  #2645
Pro10noob's Avatar
I will do so
Tight lines i can't promise but usefull info will be delivered
Regards Roy
Old 01-26-2016, 02:28 PM
  #2646
1spunspur's Avatar
Can anybody help me? I have a question per a previous conversation. Do the 1s batts. have the same connection as the 2s packs, only without the extra wire??
1spunspur is offline
Old 01-26-2016, 02:42 PM
  #2647
TOADYY's Avatar
Yes, they do. Depending on the manufacture the plug size could be 4mm or 5mm. Trinity is the only manufacture that I know of that uses 5mm plugs.
TOADYY is offline
Old 01-26-2016, 03:37 PM
  #2648
YoDog's Avatar
Trader Rating: 26 (100%+)
The Turnigy ultra also use 5mm plugs but come with replacement plugs and 4mm to 5mm adapters.
Some chargers like the iCharger need to have the tap wire connected to the (+) Positive lead in order to work properly.
YoDog is offline
Old 01-26-2016, 07:16 PM
  #2649
1spunspur's Avatar
Sorry folks, I meant to say the charge lead.
Old 01-26-2016, 09:29 PM
  #2650
Pro10noob's Avatar
Yes they do but don't connect the balancer wire to the charger if you charge them one at the time.
Some chargers can give a annoying beeping sound if it is connected at the charger but not on the battery or you have to charge them as a 2S with a connecting wire between the 2 cells.
Regards Roy
Old 01-27-2016, 12:35 AM
  #2651
1spunspur's Avatar
Regards Roy
Thanks for the info, but I've been looking around and I'm thinking the single cells are pretty expensive. I'll have to wait a bit on that. By the way, I was running it today with a rebuilt 19 x 1 brushed, and it was pretty "wild fast".
Old 01-27-2016, 03:11 AM
  #2652
Pro10noob's Avatar
Expensive???
Naahhhhh-----> http://www.hobbyking.com/hobbyking/s...Approved_.html
Regards Roy
Old 01-27-2016, 04:47 AM
  #2653
Indeed that's my set up 2x 1s lipo
Your running saddles on thet car??
You could also try 2x 1S, you got a lower cog then.
Joost. K and i have been running an Asso based car with that setup with great results.
Regards Roy
moraccio is offline
Old 01-27-2016, 06:56 AM
  #2654
1spunspur's Avatar
Expensive???
Regards Roy
That not expensive. The ones that I was looking at were at about $1. plus per mah.
Old 01-27-2016, 07:10 AM
  #2655
Pro10noob's Avatar
Ow dear
Regards Roy
