Pro 10: 235mm Le Mans Prototype Pan Car Discussion >
Like Tree1559Likes
Old 12-03-2015, 04:36 AM
  #2491
IgorR's Avatar
Default Corally parts
Hello,
Could you tell me where you get your corally parts from?
IgorR is offline
Old 12-03-2015, 05:04 AM
  #2492
Pro10noob's Avatar
Is this a general question for everybody or some one specific?
I have my supplier very close to the source.
Regards Roy.
Ps what are you looking for?
Originally Posted by IgorR
Hello,
Pro10noob is offline
Old 12-03-2015, 10:17 AM
  #2493
IgorR's Avatar
Regards Roy.
Sorry i should have been more precise. It's a question for Europeans (parts ship to France).
So far I'm looking for a rear axle, left and right hubs for 235mm, maybe a full front end (asso 5.1 like in red).
IgorR is offline
Old 12-03-2015, 12:31 PM
  #2494
Pro10noob's Avatar
I can supply you with a rear axle, right hub and short left hub.
I can also get a Asso front end but i don't have the Original Corally bulkheads that go with it to set it up on the Corally chassis.
I do have other bulkheads that do the same tho
Do you want inline axles with the front end or just the trailing type like Original??
Regards Roy
Old 12-03-2015, 03:16 PM
  #2495
Donn's Avatar
Here is a link for pan car axles, hubs and many other parts. Axle and the like you will find under the IRS link at http://www.teamgfrp.com/
Hope this helps you.
Donn is offline
Old 12-03-2015, 09:27 PM
  #2496
Pro10noob's Avatar
Corally uses a 7MM rear axle
Also the bolt pattern for the front suspension differs to that from a Associated.
Corally made a special bulkhead to use it with the 5.1 Associated parts.
Hyperdrive has a similar part.
Regards Roy
Old 12-04-2015, 10:02 AM
  #2497
Tim W.'s Avatar
Its not a 235mm but here's my 10L3T I just finished! Trying to get an open pro 10 class going at my local track!
Tim W. is offline
Old 12-04-2015, 10:38 AM
  #2498
Pro10noob's Avatar
Nice one Tim W
Regards Roy
Old 12-04-2015, 11:35 AM
  #2499
Tim W.'s Avatar
Nice one Tim W
Regards Roy
Thanks! Glad there's other guys out there that are still hooked on pro 10!
Tim W. is offline
Old 12-04-2015, 11:37 AM
  #2500
Joost K.'s Avatar
There are... WE are!!! And we will keep driving them...
Joost K. is offline
Old 12-04-2015, 12:05 PM
  #2501
What body is that and who makes it?
RoyU is offline
Old 12-04-2015, 12:27 PM
  #2502
Tim W.'s Avatar
Its a old Racers Choice body that was brand new and I just painted it last week. I have another brand new one but I'm holding on to it because they're impossible to find!
Tim W. is offline
Old 12-04-2015, 01:00 PM
  #2503
Pro10noob's Avatar
Pro10 is still alive in Europe Tim.
Thank god for that
BTW i am not hooked on Pro10 but addicted.
Can't get it out of my system and it is all Joost K his fault
Just kidding Joost
If you ever are in Europe, bring your car with you and we can run it here on our lovely tracks.
Regards Roy
Old 12-04-2015, 02:39 PM
  #2504
Joost K.'s Avatar
My bad Roy... I will, however, take full responsibility for your addiction to Pro10 & pancars...
It was, and still is, MY PLEASURE!!!
Joost K. is offline
Old 12-04-2015, 02:57 PM
  #2505
Where do you guys race in Eindhoven if you don't mind me asking?
I don't live that far away from there but my 'local' track has got some problems with dust from the motorcross bikes nearby even though they're going to install a sprinkler installation on the course to limit the dust.... fingers crossed
Affects traction on the track if you're a good driver which I'm not by a long while so I'm not affected for a while .
kooga is offline
