Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#2162
Thanks, Ron
#2163
A bit Pro10 Modified Action from the last Race in Luxembourg.
Thanks to Ben Voorhaar for filming
https://www.youtube.com/watch?v=dF7g...ature=youtu.be
#2164
#2165
Which body is the second one using (the yellow car)? Looks like the PF905b, isn't it?
I have a question about V-link rear pivot: I will soon use the VIP V-link on my 10r5.1 and I'm asking me what are the effects of the different positions to put the small links (4 points of fixation)? What brings the higher position and the lower one?
Thanks for sharing,
G-rem
#2166
If i am correctly informed the second car(the yellow one) is a Mix Nissan or a Nissan GTP.
The higher the V-link the more grip you get, the lower you put is, the more steering you will ad.
The car with the number 3 in my pics is a Mix Nissan and the one in almost the same colors is the P35 Nissan.
Regards Roy
Regards Roy
Wow, nice!
Thanks for sharing,
G-rem
Thanks for sharing,
G-rem
#2167
Almost right
It is the Nissan GTP with side Flaps in the rear (black)
Highest Position at the V Link is the lowest rollcenter and give you more rear traction. The lowest point is the highest rollcenter point.
#2168
Sweet driving, as allways Tobias!!
#2169
Thanks a lot Tobi and Roy, it is great to see such a support for a class few people (but highly passionnate) are running in!
I really like the Nissan is it this one: http://www.mrt-rcshop.de/epages/6307...op/Karosserien
Where do you find the carbon side flaps? I only found the one for the P905b on RC-devil shop...
For now I use the P905b and I really like her design (I don't really like the mix lola or the Blitz P908), so if a more classic shape body seems to work in modified class, like the Nissan or the 905b, I would prefer use it
Regards,
G-rem
Regards,
G-rem
#2170
G Rem,
it is the MX78226 Nissan GTP.
Another more classic realistic body, working in mod. is the Porsche 962, CR78227. It was the german champions body 2012.
If you need those, you can likely contact me, I'm in Aachen, not far from you!
Greetz
Johannes
Greetz
Johannes
#2171
Do I have to use the website to place an order or I can send you an e-mail for that?
Regards,
G-rem
#2173
Noted Roy, thanks!
#2174
G Rem,
you can email me or give me a call, or do a short visit in Aachen , (but with an appointment please), as you like...
BR
Johannes
BR
Johannes
