Old 09-06-2009, 10:55 AM   #1
Default Offset hubs for an 235mm rc10r5
Hello,
I'm looking for a solution to widen the rear end of my rc10r5.
For the front end I allready find something nice on fulloption web site.
Those anyone have a solution ?
Cedric from France.
kerb is offline   Reply With Quote
Old 09-06-2009, 11:01 AM   #2
2wdrive's Avatar
on the german pancar forum there was a wide conversion using longer IRS hubs. Will look into that for you if you don't read german.
2wdrive is offline   Reply With Quote
Old 09-06-2009, 11:10 AM   #3
I can't find this thread...
Old 09-06-2009, 11:18 AM   #4
2wdrive's Avatar
yeah sorry i should have typed forum
This thread:
http://www.moosi-masters.de/forum/vi...r=asc&start=15
If you scroll down then you will see a rc10r5 build to 230mm
what you need is:
- IRS wide axle IRS2101
- IRS right side Asso-Style D-Drive Hub IRS2121
- IRS 10th 1.25" left side hub IRS220
Old 09-06-2009, 11:21 AM   #5
Thanx !
Old 09-06-2009, 11:27 AM   #6
2wdrive's Avatar
no problem, You should thank AndiF for leading the way
edit:
By the way the front option widening kit will take it to 220mm. It means that the car will have a little bit less steering then with a standard width which is roughly 210mm (rc10l2, corally 10xng etc etc)
