Old 09-06-2009, 03:51 AM   #1
Default Lipo mount in your car!
Yeah i searching some nice mounts for Lipo. You can post here pics how you mount your lipo battery in your car. And patents for the best balance the car
orzel24 is offline   Reply With Quote
Old 09-06-2009, 05:27 AM   #2
bfong13's Avatar
Trader Rating: 17 (100%+)
Depends on your car, but I have the PPD Billet Base/Side Weights and Diggity Designs Wide Mounting Brace for my TC5.
bfong13 is offline   Reply With Quote
Old 09-06-2009, 05:57 AM   #3
vazzo's Avatar
Trader Rating: 100 (100%+)
I run this one http://www.rcatomic.com/atomic/index...=162&Itemid=30
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 09-06-2009, 10:06 AM   #4
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Check your side to side balance on that thing? I found with my offset DD brace I didn't need to run the PPD plate, just added 21 grams to the top of the battery strap. Just my possibly non needed in put. I race with Kevin (PPD) super good guy...
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\MIP\JConcepts\Schelle\ProlevelRC
Logi Maker is offline   Reply With Quote
Old 09-06-2009, 11:57 AM   #5
I searching for 416. Find some easy way today. I will upload some pics soon
Old 09-06-2009, 12:48 PM   #6
@vasso; are you running the atomic LIPO mount in a T2'008 five cell?
I wonder if the Atomic case fit good in the five cell version?
Skynet is offline   Reply With Quote
Old 09-06-2009, 02:23 PM   #7
vazzo's Avatar
No I run it in the T2009 but it fits the both 5 & 6 cell version without any modifications as there are two lots of screw holes; the instructions actually specify which holes to use on the 5 cell version; so it's all good. Well worth the $30 I spent.
Old 09-07-2009, 09:22 AM   #8
ok, sounds good. Do the mount fit under the top deck on the T2'008? because otherwise the mount must be placed outside the chasisplate...
Old 09-08-2009, 12:25 AM   #9
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Before I switched to the Exotek chassis, for a short time, I had the Corally (Specialized) tray in my TC5.
IIGQ4U is offline   Reply With Quote
Old 09-08-2009, 01:53 AM   #10
Verndog's Avatar
Trader Rating: 16 (100%+)
There are several variables that will cause his to balance with more weight. #1 battery size (mah). They can vary better then 2oz depending on capacity. #2 distance from centerline of chassis that battery is placed. The farther from center the less weight needed. #3 Weight of electronics on opposite side.
One bit of advise on those 21 grams. Get them off the top of the strap. That will raise your center of gravity being so high up. Try to get that weight on the chassis and you'll have less force throwing the car around in hard turns.
One of the larger benifits you'll see with a lipo plate is it lowers the center of gravity because the heavier (denser weight) is on and IN the chassis..
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 09-08-2009, 01:58 AM   #11
vazzo's Avatar
It sits outside the topdeck, Ill post up a pic later tonight.
Old 09-08-2009, 02:00 AM   #12
rezenclowd3's Avatar
Send a message via AIM to rezenclowd3
+ 1 Verndog. I also got rid of the strap, and even went so far as to buy a lighter servo that is closer to the centerline (being that its Low-Profile), even taking off the ring on the motor.
Heres mine with BOTH PPD billet Lipo plates, and no other added weight. (yet)Balances perfectly. I just push the lipo to a line I have drawn on the plate where it all balances out. I need to add about 10grams (depending on body/paint used) down the centerline to get to min weight, which is 1500g.
I have 6 bodies so I change the weight down the centerline quite frequently LOL.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 09-08-2009, 02:20 AM   #13
Verndog's Avatar
Exactly as designed. You have kept the weight on or inside the chassis edge and it balances close to min weight that way. Alot of club races nowadays aren't checking weight, so people are offsetting the batteries farther out and using less weight. There are varying opinions on that. Heavy weight hanging off the side of the chassis is only happening on 1 side. The motor hangs off, but its weight is supported closer to C/L of chassis from mount.
Yes, it will balance that way while on level surface...but once you enter a turn, the TC will act different from L to right turns since the L side weight is farther outside then the R side weight. People that have tried this know it...those that haven't think your nuts when you explain it.
Nice Pic and nice job!
---Team Hoarders---
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3147 11-21-2017 07:39 PM
CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks John Stranahan Electric On-Road 1776 03-01-2016 01:18 PM
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-25-2015 12:28 AM
Xray 007 and 008 High Quality EZ lipo mount--w Pics Verndog Electric On-Road 22 01-26-2010 01:34 PM
Platinum Lipo WorldCup2004 Electric On-Road 1192 04-24-2008 09:51 AM
FK'05 - LIPO - Min. Weight 3.306 - Lets be creative! CaliberX Electric On-Road 12 05-13-2007 02:27 PM
