brush cutting
Old 01-30-2004, 02:33 PM
sean's Avatar
Default brush cutting
i am well aware that people cut off the trailing edge of there brushes on stock motors,to effectivley advance timming and acheive more rpm. i have never done it myself or seen other people actually do it. so i was wondering- i have some trinity slotted brushes-if i were to cut away the brush at the slot(basically cutting it in half) would that be over kill? what do people mean by "a little bit" off the trailing edge? how much is a little bit?
sean is offline
Old 01-30-2004, 02:44 PM
Lonestar's Avatar
Trader Rating: 14 (100%+)
25%
what you can also do to keep the face full is to cut it with an angle.... Basically it will "wrap around" further...
how can I draw it...
originally the brush is like this
_
cut it like this (be careful to the brush length though. use stiffer springs if needed)
Not sure it makes sense....
And remember the best trick is actually driver's skills
Later
Paul
Lonestar is offline
Lonestar's Avatar
crappy drawing
Lonestar is offline
Old 01-30-2004, 02:46 PM
Korey Harbke's Avatar
That is definently overkill lol. The brush wouldn't even seat right. I just measured for you how much I take off the trailing edgeand how much putnam usually does on their motors. Normal width of the face of a laydown brush is somewhere around .190 in. I have cut about .015 in off the trailing edge of the face. So the overall brush face width is about .175 in wide. It's not much, but it does make a difference. Hope this helps you out.
-Sushi Boy
Korey Harbke is offline
Old 01-30-2004, 02:50 PM
sean's Avatar
no, the drawing was fine, it made perfect sense. i am not even at the point where a couple of thousand rpms would make a difference either way(have to keep it off the walls first ) just curious by nature and like to tinker with things. thanks-sean
sean is offline
