Old 09-03-2009, 07:10 PM   #1
drive2survive's Avatar
Trader Rating: 23 (100%+)
Default DIFF ADJUSTMENTS?
ran a TC3 around the track and in the sharp corners it wanted to do a 360 and did, even at low throttle and compound on the tires
someone suggested the front diffs were too lose so I tightend'em and it made a diffrence..ok, should the front /rear diffs be adjusted the same ? also whats the meaning of a "locked diff, that mean the adjust screw is turned in all the way so the tires will barely move? if so why?
"OLD MUSICIANS NEVER DIE, THEY JUST DE-COMPOSE"
drive2survive is offline   Reply With Quote
Old 09-03-2009, 08:36 PM   #2
cyanyde's Avatar
You can lock by doing that, which isn't very good as the diff screw may snap after awhile. The alternative solution is to use a spool instead.
cyanyde is offline   Reply With Quote
Old 09-03-2009, 09:18 PM   #3
ya might wanna enlighten me re car terms, not too familiar yet why lock? spool?
Old 09-03-2009, 11:29 PM   #4
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Last edited by Drillit; 09-04-2009 at 12:21 AM. Reason: toomuchworktookdifferentforkinroad
Drillit is offline   Reply With Quote
Old 09-04-2009, 12:15 AM   #5
94eg!'s Avatar
Trader Rating: 17 (100%+)
To answer your question, a spool is not a diff at all. It simply locks the wheels left & right. This is what you typically see when racing on a large asphalt track. If everyone else at your track is running a front spool, you should probably invest in one as well...
On a very tight asphalt course, a front diff will probably be better. Typically you run the front diff a little tighter than the rear. If your rear diff is too tight, your car can get very loose when mash on the throttle. Readjust your rear diff to be as loose as possible without slipping. Then make your front diff a little tighter than that.
94eg! is offline   Reply With Quote
Old 09-12-2009, 07:13 PM   #6
does that diff adjust apply to belt drive like a HPI sprint?
Old 09-13-2009, 01:06 AM   #7
94eg!'s Avatar
My experience is with a TRF415-MSX. This is a dual belt drive touring car. I believe the principal applies to all cars though...
Old 09-13-2009, 03:49 AM   #8
fleetmaster's Avatar
Trader Rating: 16 (100%+)
May not be a diff issue. You may have too much front grip relative to the rear.
When my local track gets gooped, we have to compensate for the extra steering.
Is it off power and when neutral throttle as well ? Or just on power ?
A spool will help pull the car out of the corners better,but tend to under steer into turns .(this can be tuned out)
A rear diff too tight will cause the rear to power slide on exit too.
Approach one of the better drivers at your track and get them to check it for you.
Most will be happy to help and experienced eyes will find problems faster.
I solved a similar problem with a Losi Type R that did a similar thing....
I traded it in on an Xray. Best thing I ever did.
Fleet.
fleetmaster is offline   Reply With Quote
Old 09-13-2009, 12:36 PM   #9
imjonah's Avatar
Default How tight is tight
The one part of kit building and car adjustment which I find most difficult and where I often find peoples advice confusing is diff building and adjusting.
As far as I know there is no diff tightness gauge, or little marks to line up or a clear procedure to test tightness.
Obviously a diff is too lose if you can easily move the pulley, while holding the out drives from moving. It is obviously too tight if the diff acts like spool or when you turn one wheel/out drive and the wheel/out drive on the other side seems to bind or the ball diff feels gritty.
I have seen two methods of testing. One is to raise the whole car up turn both wheels (on the end of the car you are testing) in the same direction and make sure you can hear/feel the motor rotate as yo urotate the wheels, if motors magnetic resistence to turning is sufficent to makr the diff slip then it is too loose.
The other method is to do the same but have the wheels on the opposite end actually contacting the surface and then see if rotating the rear two wheels will cause the wheels on the other end to rotate or will the friction from the contact with the surface hold the other ends wheels sufficiently to cause the diff to slip.
The idea is too loosen the diff until it just barely passes one of the above tests.
Note: I think it is also the case that diffs loosen themselves over time particualrly newly rebulit ones and thus need to be readjusted after the first run or two.
The other related question that I hear differing answers too is; how much diff lube to use. The most common opinion I think is that less is better and as long as each ball is covered the amount of lube is sufficent.
I have the feeling that this is one of the areas that the top pros have down pat or have their own methods and that their own techniques or rules of thumb, which are not necessarily part of our common knowledge pool.
imjonah is offline   Reply With Quote
Old 09-13-2009, 01:25 PM   #10
wiscnitro's Avatar
Trader Rating: 22 (100%+)
On the same subject. How would a Front Spool act in a TC3? Pros/Con's?? VTA on carpet. since a oneway is not a option anymore
Hold my beer and watch this! :)
wiscnitro is offline   Reply With Quote
Old 09-13-2009, 01:53 PM   #11
What a spool does is make the front of the car push coming into a corner. Since both tires will spin at the same speed, and the inner tire is on a smaller diameter circle during the corning, one of the tires must slip. This makes the car push on entry.
However, when your car starts to accelerate out of the corner, both wheels, will receive the same amount of power, allowing the front end to pull the car thru the corner, and accelerate harder. With a diff the inner wheel (it has less weight on it), will get more power then the outer wheel, causing slower acceleration, and wheel spin.
I dont know if I would run a spool on carpet. They are used more in low traction conditions. Another problem with a spool is they are hard on the outdrives, and dogbones.
Shawn.
Shawn68z is offline   Reply With Quote
Old 09-13-2009, 02:18 PM   #12
pejota's Avatar
If you are setting the TC3 diffs per the instructions try loosening the rear another 1/8th or 1/4 turn. I thought the settings in the instructions were a little tight.
On an HPI Pro 4 i've found that a fairly loose rear dif allows me to flow through tight turns.
Hope that helps.
pejota is offline   Reply With Quote
Old 09-13-2009, 02:20 PM   #13
cyanyde's Avatar
tire wear too
B-Fast RC Performance Diff Parts for LOSI AND ASSOCIATED scott54 Electric Off-Road 1713 11-12-2017 08:29 AM
Losi Smart Diff Frank L Nitro Off-Road 580 06-25-2013 12:01 PM
diff oil DiaRh34 Nitro Off-Road 13 07-08-2009 09:33 AM
Losi 8T diff question grease/fluid broke it again Nitro Off-Road 7 04-13-2009 06:54 PM
diff problems, help needed Xrayskid Electric On-Road 9 06-26-2006 11:50 AM
xxx nt sport diff Saber186 Electric Off-Road 10 04-26-2006 08:40 PM
