Old 10-07-2011, 05:05 AM   #1201
wingman2's Avatar
New GEN Xi car from CRC.
There's a new thread just for that very car on here.
Sponsored by CML Distribution - http://www.cmldistribution.co.uk
wingman2 is offline   Reply With Quote
Old 10-08-2011, 07:32 AM   #1202
avs
avs's Avatar
Originally Posted by waswadener View Post
I'm new to the Gen XL family and am getting my car ready for my first 1/12th scale race in a week or so.
I'm placing the electronics that can be moved around (Smartboost, Tekin RS, SR3500 and MRT PTX). No matter where I put the electronics, the best left-right weight balance I can get is a 25 g difference between the left and right wheels (left side being heavier).
Is the 25 g difference in lateral weight distribution big enough that it's anything to worry about? If so, I'm not sure how to achieve perfect lateral balance because the heaviest components (motor and battery) can't be moved laterally.
After fiddling with electronics placement for about two hours now, I'm beginning to think my 25 g difference in lateral balance is as close as I'm going to get. I'm tempted to servo-tape the stuff in the location that gives me the best (although not perfect) lateral balance, go drive the race and see how the car handles.
Thoughts?
Are you using 2 scales, if so does the measurement change if you reverse the car?
i balance with pins so i don't have a number but i think i get really close without ballast. the newer batteries are lighter on the post end. i put the battery post end towards the servo side then add the tekin on the opposite side as close to the shock mount as i can, then move the receiver to balance.
i don't know if it is the problem, but that 'smartboost' seems a little big and heavy. i use a hobbyking booster which is the $5 version of the $35 TQ booster
Tony Shimko
avs is offline   Reply With Quote
Old 10-19-2011, 12:23 PM   #1203
Just got into 12th scale after racing tourers for 15 years
Picked myself up a crc xl, is there anything that I need to get from the standard kit to make it competitive?
Mb3195 is offline   Reply With Quote
Old 10-19-2011, 01:03 PM   #1204
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
other then tires, the kit is good outta the box
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 10-25-2011, 05:20 PM   #1205
Jonnydb's Avatar
Send a message via MSN to Jonnydb Send a message via Skype™ to Jonnydb
im trying to buy one, if someone has selling please send a pm
thanks!
T.O.P Racing Brazil
Jonnydb is offline   Reply With Quote
Old 10-26-2011, 01:11 AM   #1206
racer x 1's Avatar
Trader Rating: 27 (100%+)
i got my eyes on this car and i know the xi is on the way but i like sales... lol are there any hop ups needed from the get go? going to run 17.5 blinky... thanks
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 10-28-2011, 08:30 AM   #1207
Three's Avatar
Curious as to what holes on the body mount posts are used for mounting the body (especially the Protoform AMR, using 42mm tires).
How low should the body be mounted?
Electric good..........
Three is offline   Reply With Quote
Old 10-28-2011, 09:50 AM   #1208
You want the body as low as possible without dragging on the carpet. Most clubs use a 3mm rule for the lowest point on the car, including the body.
A good way to mount the body is to put the car on blocks, and play with the body posts until the body is sitting flat, and the trim line is at the same height as the chassis. (I always trim my body before I paint it, so I can see what I am doing. )
I also tend to slope the bottom front of the body alittle (so the corners are just a touch higher then the center of the body). So they dont drag when entering a corner.
Shawn.
Shawn68z is offline   Reply With Quote
Old 10-28-2011, 11:03 AM   #1209
Regional Moderator
CarbonJoe's Avatar
Alternately, mount the body so that it doesn't interfere with anything under the body, then take a standard Sharpie and roll it around the flat surface that the car is on with the tip contacting the body. Cut the body on the line.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-28-2011, 04:14 PM   #1210
Three's Avatar
Yes, I understand. But.... what I would like to know is what hole on the body post do people use front and rear. Three up from the bottom of the post?
Old 10-28-2011, 07:57 PM   #1211
Still Bill's Avatar
There is no standard answer to your question because the size of your tires can influence the correct height to mount the body. Specifically, larger front tires require more body height to allow for upward travel of the wheels/tires as the suspension moves.
If there is a reference line on the sides of the body, I tend to mount the body level in relation to those lines. The sharpie method works great for providing clearance during hard cornering.
And, quite often, I drill additional holes in the front/rear body posts to optimize my body heights on pan cars. And/or, I use spacers under the body posts to add a tad of height.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 10-28-2011, 08:41 PM   #1212
Three's Avatar
WOW, it seemed like an easy question. Let me try to reword it. How much of a gap should be left between the body and tires (front and rear).
The reason I'm asking is that one hole makes the body look like a 4x4, the next one down is very close to the tires/rear pod. Thanks for the replies, just looking for examples as to clearance.
Old 10-28-2011, 08:45 PM   #1213
CanyonCarverR1's Avatar
What do you guys use to clean your tires between runs to keep the rubber from building up when running on carpet?
CanyonCarverR1 is offline   Reply With Quote
Old 10-28-2011, 09:09 PM   #1214
Mine is 1/8th to 3/16ths of an inch. I have also been cutting the entire portion behind the rear wheel lately. Supposedly I will lose rear grip with it cut, but I havnt had another car give me a body tuck in a long time.
Shawn.
Old 10-28-2011, 10:39 PM   #1215
haywood's Avatar
Trader Rating: 49 (100%+)
Lighter fluid.
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
