Old 10-08-2009, 07:57 AM   #106
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Korey Harbke View Post
You should probably mount those steering links to a lower hole on the servo saver, and add some shims under the outside pivot. Basically just make the links flatter overall. Otherwise you'll get some wild bump steer characteristics.
-Korey
I need to flatten it out for sure. I can switch to the lower hole on the servo mount too (all 4 holes do not line up ). I haven't done any setup on the front end other than snap it back together after mounting the servo. I need to swap out the ball cups, they're beat. I used a set of GH metric mounts I ordered from my LHS if anyone is curious.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 10-08-2009, 08:01 AM   #107
Originally Posted by R/C Rich View Post
A picture is worth a thousand words. Brian's car is on the right.
http://teamcrc.com/crc/images/storie...C/17.5_1-2.jpg
Pictures of the long arm setup! Finally. That's what I was thinking when I saw the parts, but wasn't sure. More fun in the basement tonight!
Old 10-08-2009, 09:05 AM   #108
Here's an idea that may help when running the servo flat to the chassis. I wanted to run my ESC in the center and the only way to do that before the XL chassis was to run the servo flat. This is what I did last year and I thought I would share.
Take another set of steering arms (part # 3252) and mount them on top of the steering block, instead of in the middle of the block as instructed in the assembly directions. Leave the steering arm in the middle of the block, but trim the area that you attach the ball to. This will act as a spacer to fill the gap in the middle of the steering block. This essentially will raise the outer ball to level out the steering tie rod turnbuckles. Alternatively, you could use high roll center balls (part # 1361) on the steering arms. Otherwise, you could use a ton of shims. And I mean a ton of shims.
Hope this info helps.
R/C Rich is offline   Reply With Quote
Old 10-08-2009, 10:34 AM   #109
Great innovations!
Old 10-08-2009, 06:55 PM   #110
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
How does the long arm upgrade improve the car?
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 10-08-2009, 08:10 PM   #111
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Could someone perhaps with a manual PM the pn for the center antenna mount/shock brace? Thanks!
AWD
Old 10-08-2009, 09:32 PM   #112
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Running a longer upper arm will help smoothen the steering out on high bite tracks. It will take away some camber gain as well. This applies on all 12th scales or pan cars.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-08-2009, 09:33 PM   #113
AWD
Gen-XL manual -
http://www.teamcrc.com/crc/downloads...ete_manual.pdf
Team CRC is offline   Reply With Quote
Old 10-09-2009, 08:26 AM   #114
I did the long arm upgrade last night and flattened out the steering linkage using the shim method. I think using standoffs might work also, but I need to take a measurement. I used almost every Losi hinge pin shim I had in my box. It took an extra couple of axle shims to give the rim plenty of clearance, but plenty of room to get the lock nut seated right. It ended up putting the bearing right at the very end of the shoulder where the thread starts. The only thing left now is the lower arm brass pivot ball.
Old 10-10-2009, 03:54 PM   #115
Its a car!
Long arm front suspension:
Glamor shot:
Side shot:
The right rear view showing booster location:
What to do with the antena?
Old 10-10-2009, 04:18 PM   #116
MrSlow's Avatar
what is the tin front brace on the left car? i havnt found this part...
also, what lipo batteries and RX volt thingy do you guys recommend?
thanks
MrSlow is offline   Reply With Quote
Old 10-10-2009, 07:40 PM   #117
Mugen10's Avatar
What is the CRC red spring compared to by other brands. My hobby shop carries more of AE spings.
Xray T4
Old 10-10-2009, 09:28 PM   #118
It is an 8 lb windtunnel brand spring in my pic.
Old 10-13-2009, 09:48 AM   #119
I'm just waiting for my antenna mast to show up. The one from the PO was pretty nicked up and the rubber tip was missing. I hope to be testing this week.
Old 10-13-2009, 10:14 AM   #120
SQC049's Avatar
Trader Rating: 16 (100%+)
I had my LHS order me the XL conversion kit for my Gen-X yesterday, but it was on backorder at Horizon. Any idea how long until it becomes available?
Thanks guys.
Andrew Parente
| Serpent America | Picco | AKA | LRP America | Desoto Racing | PT Racing Oils | TQ Wire |
SQC049 is offline   Reply With Quote
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
