Old 09-17-2011, 10:26 AM   #1126
Monkeys punk's Avatar
To be honest after taking to the pro drivers the kit set up is pretty much bang on. I was also told to get everything moving really freely makes for a good handling car. The main thing was getting the front arms to drop without binding on the caster blocks. As they were a little tight on the long arms.
Top Racing Sabre mini
Tamiya m05
Sakura zero
Monkeys punk is offline   Reply With Quote
Old 09-17-2011, 12:42 PM   #1127
Kenny L's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Weazsel View Post
Ok guys, I need a little help here. I just ordered the Gen-XL my first on-road car. I'm doing a lot of research (I read this whole thread start to finish) but there's a lot to take in at once.
I'm trying to order necessities and must-haves, I've compiled a list maybe you can let me know what I need to add or omit?
Right now I'm talking about the Gen-XL, if anyone wants to PM me accessories that I'll need (Tweak stations, tires, truers, etc) that would be cool too.
Anyway here's what I got so far:
I'm going with the Orion packs and motors.
JRPSZ3650 - JR Z3650 Digital High Speed Metal Gear Mini Race Servo
CLN1280 - CRC Rear Side Spring Set
CLN3299 - CRC VCS/Encore Spring Set (6)
CLN3277 - CRC Pro-Strut Graphite Brace w/Hardware
CLN3260 - CRC Large 1/12 Bumper
CLN3259 - CRC Small 1/12 Bumper (Which one? Large or Small?)
CLN1764 - CRC 4mm Carbon Fiber Top Plate
CLN3351 - CRC Aluminum Left Side Bulkhead
CLN4168 - CRC 1/12 BA004 "Bomb'R" Clear Body
CLN4166 - CRC R10 Pacemaker Light Weight 1/12th Body
CLN4167 - CRC Audi R8C Light Weight 1/12th Body
Which body is the hot ticket?
Anything spares you guys could recommend? Anything I need/don't need? Thanks in advance...
The r8c is what most of the team runs. Small bumper is fine. the braces and long arms aren't needed for stock racing if that's what your planning on running. Start with kit setup with the r8c body ,green center spring , 20 to 30k in tubes not kit stuff then adjust from there. Are you planning on running at Donny's track? I'll be down most likely for opening weekend if you have questions or need help. My stock car is as dialed as it gets. The brass pivot ball are good but take more up keep. I run them in my 13.5 car. Get a number 46 drill to drill upper arms to make then super smooth any true value type hardware store will have it cheap.
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 09-17-2011, 07:32 PM   #1128
JustWill75's Avatar
Send a message via AIM to JustWill75
Is it better to have the servo mounted flat or angled?
Do most of you set your car up to be balanced on both side when placed on the the spikes?
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 09-17-2011, 07:44 PM   #1129
Still Bill's Avatar
You should get a lot of feedback about flat or angled. To me...not much difference; except, you get a lower CG with flat (which can be a positive in the right circumstance).
I, for one, always balance my cars using Irrgang Racing Services Balance Buttons. Mo better than the spikes.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 09-18-2011, 09:35 AM   #1130
Craig's Avatar
Send a message via AIM to Craig
Default Tire recommentions
Ordering my XL on monday, need some help with setup,gearing and tire compound,but mostly tires. The local track just moved there carpet track and laid down new ozite,but no one knows what compound tires to start off with? We will be running 13.5 in blinky mode. Whats a good safe starting compound and maybe next harder up if traction should come around. Also the track doesn't allow paragon. Thanks for any help..
Craig is offline   Reply With Quote
Old 09-18-2011, 10:40 AM   #1131
Craig's Avatar
Old 09-18-2011, 11:44 AM   #1132
CypressMidWest's Avatar
Pink Rears and Pink or Magenta fronts will work very well. For sauce I'd suggest SXT 3.0.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 09-18-2011, 06:05 PM   #1133
Korey Harbke's Avatar
Also, if you notice a bunch of fuzz buildup on the tires and a loss of grip later in the run, maybe try black fronts and yellow rears. They tend to collect less junk on them as the run goes on. After you figure that out, its pretty easy .
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 09-18-2011, 07:45 PM   #1134
kingbee9's Avatar
Trader Rating: 30 (100%+)
I pretty much run Magenta fronts and Orange rears all the time. I just adjust my sauce in the front for the traction level. Super glue on the outside bead of the tire. SXT 3.0 is very good. Orange tires are the Yellows that Korey suggested but with a gray sidewall for less chunking. Yellows work very well too.
Brian Wedge
www.ashfordhobby.com
NORCAR R/C Racing at The Gate
www.norcarracing.com
kingbee9 is offline   Reply With Quote
Old 09-18-2011, 07:51 PM   #1135
kingbee9's Avatar
Can't go wrong with advice from Kenny, his cars ARE dialed.
Brian Wedge
Old 09-19-2011, 05:57 AM   #1136
WIITA's Avatar
Trader Rating: 42 (100%+)
I would suggest running either running pink or graylow rears along with black or magenta fronts. Personally I always run magenta fronts and graylow rears. Only time I run a pink rear is when I run mod or 13.5 open. Make sure to dial out dual rate as needed. I typically dial out as much as I can to get around the tightest corner on the track and then add a few more clicks. A few other things that help with the car is the slide in ride height spacers for the front and the 4mm top brace in the rear. Building the front end correctly IMO is the most important part on the xl. Make sure everything drops under it's own weight and there is no binding at all. Also, pay close attention to the rear Ctr pivot to make sure it all moves freely. The car is crazy dialed when everything is working correctly.
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Old 09-19-2011, 11:50 AM   #1137
Craig's Avatar
So when you go to mod you basically go to a harder tire to allow for more rotation?
Old 09-19-2011, 05:52 PM   #1138
CorallyBQuiK's Avatar
Trader Rating: 21 (100%+)
Now you have to be carefull on what brand of tires you are talking about because shore and color rating somewhat change from company to company. We usually always run CRC/BSR pink rears and magenta fronts and when traction comes up like korey said we will go to yellow or graylow rears and black fronts.
Tyler
Team CRC - Corally USA/Specialized RC International - FF'07 RC Concepts - Hurricane Motorsports - Ken"s Graf/x - Team PRCP - Team Genesis R/C
CorallyBQuiK is offline   Reply With Quote
Old 09-19-2011, 05:56 PM   #1139
Infinite 12th's Avatar
Tyler
Are greylow and grey different?
Infinite 12th is offline   Reply With Quote
Old 09-19-2011, 06:00 PM   #1140
Yes, the graylow is a dual compound, It's a yellow tire with an outside band of gray. Jaco's version is called orange.
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
