Old 05-17-2011, 12:07 AM   #1021
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Has anyone else noticed that their bellville washer, spacer and diff nut bottom out with the new 16 ball 3/32 diff set up? I am assuming it is caused by the thinner stack created by the use of smaller diameter balls... Anyone found a quality workaround or fix? I have a random 1/4" id shim between my belllville and spacer collar, but am looking for something a little more reliable. I am not certain the shim won't float around and cause inconsistent diff action because there is very little CF axle shaft extending past the spacer collar.
Old 05-21-2011, 09:45 AM   #1022
Still Bill's Avatar
Andrew,
Give a shout to Brian Bodine at Slapmaster Tools for one of his fantastic Slapmaster thrust bearing assemblies. Brian already has a workaround for the issue. No bellville washer setup for me...
You should remember Brian B winning two pan car classes at the IIC last year...But, who is counting?
And I love the 16 ball spurs.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 05-21-2011, 06:31 PM   #1023
This is actually an old problem. For my pan without a thrust bearing, you can put acouple of washers before the cone to take up the extra space. This will prevent the nut from bottoming out. I didnt have any washers that fit on the axle properly,so I put on between the nut, and the bevile washer, and it works fine too.
If you want a thrust washer, buy the serpent 120 one, it fits the car perfectly, and you can have it installed for $10.
Shawn
Shawn68z is offline   Reply With Quote
Old 05-23-2011, 09:55 PM   #1024
CypressMidWest's Avatar
Even with the old spurs, I run two bellville washers in a )( configuration. It allows for a finer adjustment since you now have the spring action of two washers.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 05-23-2011, 10:56 PM   #1025
Definitely good advice, but just for clarity, I don't think a second bellville will improve this condition. Adding a brass, .5 mm thick, narrow OD shim between the outer bearing and the red spacer has solved the problem. Simple and efficient. Thanks to all for the suggestions.
Old 06-26-2011, 11:54 AM   #1026
bsmooth's Avatar
Trader Rating: 17 (100%+)
The Slapmaster thrust bearing is a must have. I have them on both my GenX cars, and it makes diff adjustments a no-brainer.
Can someone suggest the latest and greatest body style for 13.5 ramping on carpet?
Thanks,
Steve
bsmooth is offline   Reply With Quote
Old 06-26-2011, 12:06 PM   #1027
I'm partial to the AMR-12 or the Bomb-R
Old 06-26-2011, 05:04 PM   #1028
bsmooth's Avatar
Good. Thank you.
Old 06-26-2011, 09:19 PM   #1029
Still Bill's Avatar
I do like the CRC AMR-12 as my favorite lightweight body.
Otherwise, the old Parma Speed 8 is a most durable standard weight (.030) body at about 25-30 grams heavier.
Bill
Old 06-26-2011, 09:20 PM   #1030
Still Bill's Avatar
I do like the CRC AMR-12 as my favorite lightweight (.020) body.
Bill
Old 07-22-2011, 07:03 PM   #1031
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Default New to 12th scale
Going to be picking up my 1st 12th scale kit and would like to know what additional spare parts/hop ups I should get for the Gen-XL? Planning on running 13.5 non-boosted on indoor asphalt track.
springs?
oil/lubes?
shims?
spur/pinions?
tr1kstanc3 is offline   Reply With Quote
Old 07-22-2011, 07:22 PM   #1032
I have a Gen X 10 and the quality is over the top. The precision of the parts, the fit and finish, and the finished product is so good I haven't even thought of upgrades yet. My kit came with several shims for the front and rear ride height adjusters but I think they have additional thicknesses if you need them. I haven't really had time to put the car though it's paces but I think that different tweak springs, steering blocks, and a number of spur, pinion combos are all good things to have on hand. The only hop ups so far are Lunsford Ti Rods with RPM ball cups and Robinson spurs and pinions.
Steve. is offline   Reply With Quote
Old 07-22-2011, 07:47 PM   #1033
Fred Hubbard's Avatar
Default New GenXL for sale
Anyone looking for a car?
Great deal on a 1 month old car
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 07-24-2011, 11:04 PM   #1034
Trader Rating: 65 (100%+)
Send a message via ICQ to Barneys Racing Send a message via AIM to Barneys Racing
springs?
oil/lubes?
shims?
spur/pinions?
front wheel bearings
diff and axle bearings
steering blocks
kingpins
links
front springs
tweak springs
upgrade to aluminum left pod plate
tires, tires, and more tires
have a spare of just about all of the front end parts i.e. arms, steering blocks, axles, etc.
something like 30,000 diff lube for king pins (even heavier adds a damping effect to the king pin)
ask someone at your track what gearing they're running and start there. also ask them what they're putting on the damper tubes and what shock oil they have in. ask what tweak springs and center shock spring work best for your track.
that's some of the stuff that i keep around. hope that helps.
Barneys Racing is offline   Reply With Quote
Old 07-25-2011, 12:09 AM   #1035
Still Bill's Avatar
springs?
oil/lubes?
shims?
spur/pinions?
Check out Fred Hubbard's car that is for sale above. Fred maintains super nice cars.
Bill
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
