Old 03-20-2011, 11:05 AM   #976
Originally Posted by Slapmaster6000 View Post
Assuming you are running a spec motor; 17.5-13.5...... Kit set up with yellow - blacks, 43/42mm. 1/2* cam, caster 1 forward, 2 rearward, white sides just touching, battery forward... rearward if you need more off power steering. Sauce fronts about 3/4. 3.25 under the nose, 3.5 at the rear for ride height. Have fun!
Brian
No forgot to say I am running Mod class only class we run over here
Christian
chovden is offline   Reply With Quote
Old 03-20-2011, 11:44 AM   #977
Default Newbie
I'm new to 12th scale and had a few ??. I brought a crc and the corner of the chassis is split can I just glue it back together? or should I buy new chassis? also do you have to use setup gauges on these cars?
thanks in advance
Travelg Amateur is offline   Reply With Quote
Old 03-20-2011, 12:26 PM   #978
Trader Rating: 41 (100%+)
thanks in advance
I would just use some CA and glue it back together I also sand and glue the entire edge all the way around
ANd No I just use a camber gauge, Ride height Gauge and a hobby knife for tweak
jdeadman is offline   Reply With Quote
Old 03-20-2011, 08:12 PM   #979
Trader Rating: 24 (100%+)
Send a message via AIM to Max K
Christian
This is what I run on my home track for mod. Really low bite!
.50 fronts
10,000wt on kingpin
0 deg camber
5 deg caster
all shims back
batt forward
30wt in shock
blue center spring
white side spring
10,000 wt in tubes
magenta front
pink rear
The car is still gonna be loose no matter what. but this is the closest I've gotten to a mod car that handles all right on low bite. If traction comes up just go to heavier lube on kingpin and in the tubes. Let me know how it goes!
RC America - XRAY - HUDY - Trinity - ORCA - Sanwa - ULTI - PROTOform - MaxFX - Slapmaster Tools - ApexRC - SXT
Max K is offline   Reply With Quote
Old 03-21-2011, 12:12 AM   #980
.50 fronts
10,000wt on kingpin
0 deg camber
5 deg caster
all shims back
batt forward
30wt in shock
blue center spring
white side spring
10,000 wt in tubes
magenta front
pink rear
Thanks I will try it and hope to do good with it.
Christian
Old 03-22-2011, 06:52 PM   #981
Thanks!
And is there some different screws that you can use? the red ones strip to easy.
Old 03-22-2011, 06:54 PM   #982
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I just bought steel screws from AE in the correct heads and lengths. I can still make minimum weight and stay balanced. Plus I don't worry about stripping or breaking screws.
Old 03-22-2011, 08:35 PM   #983
Still Bill's Avatar
Thanks!hep
Check RCScrewz for stainless steel (low cost) or Lunsford for titanium (expensive).
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-22-2011, 08:52 PM   #984
avs
avs's Avatar
Thanks!
tony's screws stocks high quality steel screws(the same high quality fasteners that AE puts in their kits). the only snag, there is no genxl kit currently. but a request might help change that.
Tony Shimko
avs is offline   Reply With Quote
Old 03-22-2011, 09:51 PM   #985
CypressMidWest's Avatar
One thing I've discovered is that the CRC red aluminum screws work very well, as long as you have a QUALITY driver, like a Hudy, EDS, or AE Factory Team (the set I use wrench). I had problems with all brands of alu screws when I was using my Integy wrenches, but since the move to better tools, I RARELY strip one.
But if you insist on steel screws, CRC also has high quality stainless hardware.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 03-22-2011, 10:25 PM   #986
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
I was just going to echo the same comment. Look at your drivers to see if they are not up the task. I have screws in my CRC kit going on 2 years old that are just fine, but I have a good set of drivers. Make sure you have a good #3 phillips driver to, not one that's been cold chisel in a past life.
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 03-23-2011, 12:21 PM   #987
Just finishing up my new XL, if anybody have any pictures of how they set up their electronics I would appreciate it. I am using a Tekin speed control.
thanks
chuck
mackin is offline   Reply With Quote
Old 03-23-2011, 02:34 PM   #988
Default electronics pics
if you go to the CRC site and scroll thru their various race reports, they generally show pictures of the team drivers' cars who have won and/or TQ'd at the important races. Some of the team guys have their speedos on the left side, some on the right, and some in the middle (directly behind the servo). It's worth noting that lately, more and more of the team guys seem to be running their servos mounted flat to the chassis (which is a relatively recent trend among the CRC pilots). There are plenty of cars posted on the site to give you the arrangement no matter which way you prefer. Largely it depends on whether or not you run a JR servo. That one mounts slightly right of center, and most of the others mount left of center (using the holes that CRC pre-drills in the chassis so that you can center up the shaft on most any type of servo). So long as your stuff is reasonably balanced and your servo shaft is on the car's centerline, you should be fine.
thanks
chuck
vafactor is offline   Reply With Quote
Old 03-23-2011, 05:10 PM   #989
wingman2's Avatar
Hi guys, I have a couple of questions for you.
First up, is this front cross brace available:
And secondly, this rear pod looks intresting:
It says on the CRC website that you will need another motor plate to complete the new rear end, but would n't the hole for the bearing holder be milled the wrong way around if you put another motor plate on the other side??
Just a bit confused with that, hopefully you guys can help!
Cheers.
Sponsored by CML Distribution - http://www.cmldistribution.co.uk
wingman2 is offline   Reply With Quote
Old 03-23-2011, 05:34 PM   #990
I don't know about the front brace...
As for the motor mount bearing recess; the plates are machined with a symmetrical recess on both sides.
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
