Old 01-23-2011, 01:45 PM   #931
wingracer's Avatar
Trader Rating: 24 (100%+)
Originally Posted by wingman2 View Post
Hi guys, I am building up a Gen XL at the moment and have a question for you. I can't seem to move the motor that far forward to get the correct gear mesh as a screw that passes up through the bottom pod plate and into the side plate seems to be stopping it. It is not actually the screw, but the round bit in the carbon that holds the screw. Anyone else have this problem? Cheers, Chris.
Yes. I like to run the motor as far forward as I can get it and a little grinding on the plate (and just a tick on the screw) allows me to get it MUCH further forward. Car was flat out PERFECT at Debby's last night.
Most people just run a smaller spur/pinion and run the motor further back.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-23-2011, 11:51 PM   #932
CypressMidWest's Avatar
Originally Posted by mdowney View Post
Coming from racing Mini-Z would you guys say that a 1/12 handles more like a 2wd Mini-Z than a 1/10 TC? I have a TC6 and raced it once on my local carpet track but felt like the car was all over the place. I'm thinking 1/12 will have a more familiar feel for me?
The feel should be much closer to the mini-z, especially if you were running foams on your mini-z. Plus, the 12th scalers are far easier to get a base set-up with than most TC's.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 01-24-2011, 12:03 AM   #933
Korey Harbke's Avatar
I'm thinking so Mikey. Most of the time my 1/12 setup doesn't change. I just play with tire more than anything else. Everything else is personal preference in my opinion. 1/12s usually always handle like a slot car if they are built correctly
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-30-2011, 02:38 PM   #934
team green's Avatar
Just want to thank Bill Deras team CRC for the new kingpins...
I will never go back to brushed motors or NIMH's!!!!
Awesomatix EVO2
Mugen MTC1
Associated B6
TLR 22-4 2.0
team green is offline   Reply With Quote
Old 01-30-2011, 09:16 PM   #935
Still Bill's Avatar
Frank made me do it...LOL. Truly, I really like being a help.
And as of today, I am the proud owner of an XL to go with my LE.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-30-2011, 11:24 PM   #936
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Does anyone have a link to the diagram showing which dimples are for which 1/12th scale on the Black Art bodies? I googled it but no luck.
nm
http://members.chello.at/blackart/pr...es/dimples.pdf
Old 01-31-2011, 07:50 PM   #937
Still Bill's Avatar
Andrew,
Let me build up my new XL and I'll help you...
Hopefully see you at the IIC kiddo.
Bill
Old 01-31-2011, 09:49 PM   #938
I like being called kiddo!
I found the link. It should be in my original post.
IIC it is. I am sure I can get Yang to go as well. We just gotta work on Scotty when he's down here in Dallas over the summer. Hopefully we know before then though. I am keeping my fingers crossed for the Oct. dates.
LMK if you need any help with the GXL.
Old 01-31-2011, 10:57 PM   #939
Still Bill's Avatar
What?!? Lots of XLs here at Nor-Cal to bum a setup from....Plus Tim!
Old 02-01-2011, 06:40 AM   #940
Trader Rating: 20 (100%+)
Default New to me GEN XL
I recently picked up a gen xl. I have never raced 12th scale and want to give it a try. I would appricate if someone could pm a good base setup to work with. Understanding I have no 12th scale runs under my belt. I plan on using a sp 17.5 and hw 1 cell esc.
Any links to balancing or any related 12th info would be appreciated.
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 02-02-2011, 11:10 PM   #941
Send a message via AIM to Max K
The box stock setup works very well for a starting point. Start with Magenta front pink rear, or black front yellow rear for tires. Make sure that the side links and your pivot is free from any binding, as this can hurt the handling on your car substantially. Start with that and let me know if you need anything else.
RC America - XRAY - HUDY - Trinity - ORCA - Sanwa - ULTI - PROTOform - MaxFX - Slapmaster Tools - ApexRC - SXT
Max K is offline   Reply With Quote
Old 02-03-2011, 09:28 AM   #942
Andrew Knapp's Avatar
Send a message via AIM to Andrew Knapp Send a message via Yahoo to Andrew Knapp
2011 Snowbird Nationals Setup
TQ+Win in 17.5 GTP
50 front springs
.404 on front springs
5 degree caster
.5 degree camber
old red center spring
stock center shock oil
3.5mm ride height front/rear
white side springs, just touching
50000 crc dampning lube
Magenta front-1.59in GLued up
greylow rear - 1.67in
Black art body
car was dialed!
TQ 13.5 12th scale
55 front springs
5 degree caster
.5 degree camber
H brace on front
alot of droup
Magenta front-1.58in GLued up
pink - 1.66in
Black Art Body
and it was dialed!!
Team CRC www.teamcrc.com--Team Trinity--Revtech--Team Spektrum www.spektrumrc.com--protoform--SXT--Rapid Competition RC Raceway and my dad!
Andrew Knapp is offline   Reply With Quote
Old 02-03-2011, 10:50 AM   #943
Default Thank you
Thanks for the info. I will give the kit base setup a try.
TLR 22
Desc410r
Old 02-03-2011, 01:41 PM   #944
bsmooth's Avatar
Trader Rating: 17 (100%+)
Are any of you mounting the servo flat on the chassis? Its my understanding that it could make an already twitchy car, more nervous, due to increased ackerman. Is this this case? My goal is to get the servo as low as possible.
Thanks,
Steve
bsmooth is offline   Reply With Quote
Old 02-03-2011, 03:09 PM   #945
Thanks,
Steve
Hey, Steve!
I just switched to the flat servo on my Gen-XL 12. It is more agressive but so far, I think I like it better.
Crashby is offline   Reply With Quote
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
