Old 12-06-2010, 10:24 PM   #871
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Shawn68z View Post
Nope, the guys in our club have been snapping them clean off! Not a bent one in sight.
I honestly think it must be a bad batch or something. I have been running my 3.2R with the prostrut front end now for 3-4 years, and have not broken one yet, but I have seen 4-5 broken in the last couple of weeks on the XL cars.
Shawn.
Is anyone seeing any correlation between the bronze pivot balls and the bent/broken kingpins? I've never run my kit without the bronze balls and I would rather not believe there was a bad run of the kingpins.
Old 12-07-2010, 12:44 AM   #872
TrevCoult's Avatar
From my experience people running the bronze balls snap kingpins, ones running the plastic balls bend them.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 12-07-2010, 12:54 AM   #873
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Trev
So what you are saying is its all depends on what kind of balls you have?
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 12-07-2010, 01:13 AM   #874
TOM NAVY's Avatar
Originally Posted by racer357 View Post
Did you buy a 12th scale or tenth scale. The LE is a tenth scale.
yeah a tenth scale sorry wrong place
|RUTHLESS RACING | I.F.R.C!!
|CAPRICORN LAB CO2 | "NO MORE BULLSHIT!!!"
"GENIUS HAS ITS LIMITS STUPIDITY HAS NO LIMIT"E.E
"MONEY TELLS NO LIES" SPONSOR WANTED
TOM NAVY is offline   Reply With Quote
Old 12-07-2010, 01:27 AM   #875
The LE's are on the way TOM. Don't worry too much about setup. The team will be involved in getting it sorted for our track conditions. We will get it fast!
Paul H
Old 12-07-2010, 03:52 AM   #876
Difficult to say,
a guy at the club runs plastic balls and broke his king pin,
I run bronze pivot balls and bent a king pin, last year I used plastic pivot ball and broke one but the king pin was OK.
I would say it depends how you crash, of the impact force.
Ralf is offline   Reply With Quote
Old 12-07-2010, 04:55 AM   #877
TrevCoult's Avatar
Oh definitely
The metal against metal seems to make it easier to snap the kingpins, less give. Of course there are always exceptions.
Trev
Schumacher Racing
Old 12-07-2010, 05:38 AM   #878
So much for my theory. I've bent about 6 in the last two weeks and broken none and I am running the bronze balls.
Old 12-07-2010, 05:56 AM   #879
Originally Posted by sg1 View Post
Hey guys,
I thought I'd post some pics and the set up I used at the US Indoorchamps.
This set up TQ'ed and won the A main masters
Front:
1.61" magenta, sidewall glued
2 shims on axle to space wheel out
10* castor blocks
stock upper a-arms
.50mm springs with .005" droop
20,000 lube on kingpins
servo flat
3 3/4mm clearance
rear:
1.66" magenta, seam glued
max. width
white side springs, .01" off of bottom plate
20,000 side tube lube
25wt. oil with red spring
1mm droop
4 1/4mm clearance
If you have any questions or comments let me know
Attachment 675369
Attachment 675370
Congrats on your win! What body did you run?
I am an experienced racer but new to the disciplin and I have a few questions about tire "management". Anyone feel free to shime in about an efficient strategy to have some practice time on tires without burning too many.
Do you practice or race with your tires at a larger diameter before getting them to that size? If so, how does it affect your setup?
How many runs can you get from tires that size?
thanks in advance.
Jeppi is offline   Reply With Quote
Old 12-07-2010, 06:24 AM   #880
I have the bronze balls in my car and started having problems bending hingepins. I started leaving the clamping screw out of the arm and I have much better luck now. So far I haven't had the ball pop out yet.
racer357 is offline   Reply With Quote
Old 12-07-2010, 06:42 AM   #881
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Thanks for the congrats!
I ran all my "race" tires in 1 practice heat each.
I started at 1.69" rear 1.64" fronts
I think on a low bite tracks, those diameters and added ground clearance actually help with traction.
For qualifing I skimmed them, 1.69" rear and 1.63" front for the first run.
Every run I took off .01"
For the main, that was the 4th run on that set.
I was at 1.66" rea and 1.61" front.
Traction was high and that diameter was perfect
thanks in advance.
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 12-07-2010, 08:39 AM   #882
Thanks for the help.
You put 20k tube lube on the king pins. Does it give you a dampening effect? is that commun practice?
I used a parma speed 8 HD body (not LW to handle my first runs crash). I have an unpainted parma Zytec 04s light, should i prepare it to try it on? Is there any other body i should get or those two could do the job?
I will be racing on a high traction carpet.
Old 12-07-2010, 09:01 AM   #883
sg1
sg1's Avatar
The lube was for dampening. I've always used some type of lube for dampening to slow things down.
I run a Parma speed 8. My car set up seems to work the best with it. I tried other Parma bodies, but liked the speed 8 the best.
Old 12-07-2010, 09:07 AM   #884
danthrc's Avatar
I have a carpet knife 3.2 and just finished painting two new bodies for it. I want to upgrade to the Gen XL. Are the body posts in a different location on the XL in comparison to the 3.2?
danthrc is offline   Reply With Quote
Old 12-07-2010, 09:38 AM   #885
Trader Rating: 41 (100%+)
Yes they are. I recently switched and the gen x is about 1cm further back and slightly closer together in the rear. All of my bodies now have 2 sets of rear holes. Blarrrggg
But the fronts are the same
jdeadman is offline   Reply With Quote
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
