New Team CRC Gen-XL >
New Team CRC Gen-XL
New Team CRC Gen-XL
Old 11-08-2010, 06:44 AM
  #811
Originally Posted by vafactor
I run a motor side plate on both sides with a hand made graphite top plate to tie the two side plates together. It's not as easy now to drop in a motor as compared to the standard XL wide open pod design. But the pod is much stiffer. And since I've done this, bent motor side plates have become a thing of the past. The team guys win plenty of races with the kit setup. I just feel more confident with a stiffer and more robust pod assembly.
I got a genx that had this left side mount and made a top deck that goes to it to help with the broken top deck, and also not too bad getting a motor in and out.
http://ashfordhobby.com/detail.aspx?ID=5388
bgrick is offline
Old 11-08-2010, 10:29 AM
  #812
CanyonCarverR1's Avatar
Default Spring rate chart
Does anybody have a chart or list of the shock spring rates?
CanyonCarverR1 is offline
Old 11-08-2010, 11:22 AM
  #813
Kenny L's Avatar
Trader Rating: 16 (100%+)
I have list of CRC vs old springs
Black=Stiffer than Copper
Purple=Copper
Green=Red
Red=Gold
White=Blue
Blue=Silver
Kenny L is offline
Old 11-08-2010, 03:03 PM
  #814
Are those arranged from Stiffest(black) to softest(blue)?
Purple=Copper
Green=Red
Red=Gold
White=Blue
Blue=Silver
Old 11-08-2010, 03:17 PM
  #815
troyer25's Avatar
Yes
troyer25 is offline
Old 11-08-2010, 03:23 PM
  #816
Korey Harbke's Avatar
And one other cool note... They follow the same color identification system that the side springs have. It makes it really easy to remember which spring is stiffer or softer.
-Korey
Korey Harbke is offline
Old 11-08-2010, 04:39 PM
  #817
Please note that the picture in bgrick's post shows an older edition GenX (not a GenXL) car. The older cars were designed for brushed motors. They had a narrower rear pod that used a longer diff side hub. When the GenXL came out with it's openX pod design, it was optimized for the larger size and heavier weight of brushless motors. The GenXL cars have the motor plate moved farther to the right and they use a shorter diff hub to compensate for the new motor mount position. So if you want the GenXL's optimum brushless motor position, and you also want an extra stiff pod that has graphite connecting the two alum side plates at the top, then it's necessary to make your own top graphite piece. If you do, then you can use any motor side plate, an older version left side plate (or a motor plate on the left side), a GenXL bottom plate, a GenXL (shorter) diff hub, and your own custom top graphite piece to tie it all together. Having said all of that, CRC has proven time and time again with plenty of high level victories that the current GenXL car runs great without need for any modifications at all.
vafactor is offline
Old 11-09-2010, 08:34 AM
  #818
I have a question for you more experienced CRC drivers:
Our local track(NorCal) is putting in new CRC carpet. In general, should I soften up my setup with lighter springs/oil/tubelube, or just use higher grip tires, or both?
Any suggestions would be appriciated.
Thx,
Greg
Old 11-09-2010, 12:42 PM
  #819
I would probably just go back to the kit setup (it actually works REALLY well) and work with tires to start. Then after you figure out what tires give you the best balance in grip, and last the whole 8 minutes, then start tweaking on the suspension if you need more grip.
-Korey
Old 11-13-2010, 12:37 PM
  #820
Default Central Shock length
Hi,
what length do you use regarding the central shock please.
thanks !
Ralf is offline
Old 11-13-2010, 01:27 PM
  #821
Mugen10's Avatar
Originally Posted by Ralf
Hi,
thanks !
Set your shock length according to droop. Exp. set your car on flat surface and set ride height to 4mm all around then use your ride height gauge between the pod and chassis and pull up on the upper shock until the rear wheels are about to raise. That is the droop you measure. I run 1mm of droop on a small tight carpet track.
screw in or out the shock shaft to get the droop you are trying to reach.
Mugen10 is offline
Old 11-13-2010, 02:01 PM
  #822
Thanks Mugen !
Ralf is offline
Old 11-13-2010, 04:17 PM
  #823
rcko's Avatar
Trader Rating: 15 (100%+)
what is the weight or the cSt of the stock white dampner lube. also, the new crc lube in the toothpaste tube, is that weight or cSt.
I put some xRay 20,000 cSt on the dampner tubes and man, it felt weird. Too stiff. I am wondering now, since 20000 weight would be much thicker than 20000cSt
rcko is offline
Old 11-13-2010, 04:47 PM
  #824
RDOUBLEDAY's Avatar
Ive been racing my crc alot lately, It drives GREAT. I pulled one of the fastest laps with it in a 6min race. We ran a 8min main and after 6min in the car went to crap. No traction at all. What should i do. And i didnt take any practice laps. I am using jack the gripper. Yellow rears, magenta fronts, CRC carpet. Any question just ask me.
RDOUBLEDAY is offline
Old 11-13-2010, 05:42 PM
  #825
Kenny L's Avatar
Are your front tires building up? what motor?
Kenny L is offline
