New Team CRC Gen-XL
#646
so the pin brace replaces the two shims and you move it and the one shim front to back for caster changes?
#647
So I tend to get really bored with graphite from broken rear pods, and just general CRC parts. Here's a little front end brace I made up with a couple peices, 2 screws and o rings. It's not the best design because the 4 screws going into the dynamic caster blocks are about 1mm to big in diameter, allowing some movement with high force. But hey, Its something I like to do so who cares. Enjoy
#648
Battery Replacement
Does anyone know if there is an aftermarket part to replace the center shock tower on the Gen XL that has a different release for the shock? Popping the shock off everytime to change the battery is wearing out the ball cups and is a hassle. If not is the a better tool than pliers to pop it off without damaging it?
#649
Google "3Racing Ball End Remover"
#650
http://www3.towerhobbies.com/cgi-bin...?&I=LXYCH4&P=7
or
http://www3.towerhobbies.com/cgi-bin...?&I=LXFV40&P=7
#651
I'm using a hex ball cup and ball from an Xray FK'04. Uses a 3mm wrench to remove. Simple.
#652
Selling a pretty dialed XL, pm me for more details, here's the link
http://www.rctech.net/forum/r-c-item...ny-spares.html
#653
Mark506, That is a pretty cool front brace. Not sure if I would need it on our small track. As for the rear upper brace breaking. Buy the 3mm upper brace and your problems are over.
I had a problem with the upper brace breaking and the lower pod breaking on the side of the short plastic bearing mount. So I got the 3mm upper brace and the long left side Al. bearing brace. Problem solved
#654
Do any of you guys know if any makes a 1/8th front axle for the GEN-XL?
Thanks for your help in advance
#656
the xbrace is not stock. I think it was slapmaster guy that made it although don't quote me. I got one for my car at snowbirds since one of the drivers decided to trade teams... I have pictures of it from snowbirds on my site www.rc50.com. not sure about the new chassis. knowing frank that is a possiblilty. he likes to try stuff.
#660
