Old 02-15-2010, 08:39 PM   #631
Originally Posted by asfastasu View Post
Does anyone know if the top plate from the brushless offset pod for the gen-xl is the same one that comes in the kit from the Gen-X10 or Battle-axe?
Yes I believe it is
Bobinmt is offline   Reply With Quote
Old 02-15-2010, 09:04 PM   #632
Originally Posted by Bobinmt View Post
Yes I believe it is
Ok, thanks alot!!
asfastasu is offline   Reply With Quote
Old 02-19-2010, 11:15 AM   #633
Trader Rating: 26 (100%+)
Default Battery ???
Is there a definate advantage in using a 1s 3.7 lipo w/booster or w/receiver pack over a 1s 3.7 lipo saddle pack in the Gen XL or in general for racing? Is the weight difference significant? Is there a difference in performance?
svines1972 is offline   Reply With Quote
Old 02-19-2010, 12:08 PM   #634
JayL's Avatar
looking for a complete asphalt setup, all I can find is "use the stock one" is that still the way to go?
I could also use gearing/esc settings help, and tires, lol
track: Speedworld 100+straight Asphalt
esc tekin rs pro
batt: TP 40c 1s
motor Duo1 13.5
LiFe recv pack, not a booster
Thanks for any help!
JayL is offline   Reply With Quote
Old 02-19-2010, 04:01 PM   #635
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
esc tekin rs pro
batt: TP 40c 1s
motor Duo1 13.5
Check out here:
http://translate.googleusercontent.c...IWccDvYYmKBThQ
The last few are XL setups
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 02-20-2010, 09:08 AM   #636
avs
avs's Avatar
the saddle pack is meant for tbar cars. the genxl is a link car. i havent seen one but i imagine the saddle pack to be like 2 pairs of subc batteries.
i guess you could use it on a link car if you swap back and forth with your tbar car, but no other advantage.
Tony Shimko
avs is offline   Reply With Quote
Old 02-20-2010, 09:51 AM   #637
whynot's Avatar
Trader Rating: 18 (100%+)
If you use the saddle packs you can prob. take the batts out without having to pop the shock off every time
whynot is offline   Reply With Quote
Old 02-20-2010, 09:32 PM   #638
avs
avs's Avatar
makes sense, but how would it be to tape them down?
Tony Shimko
Old 02-20-2010, 09:40 PM   #639
whynot's Avatar
they would prob. be easier to tape down and hold better since each section is lighter.
Old 02-23-2010, 07:59 PM   #640
I just got a GEN XL and now I am looking for some tires. I have run jaco and rc4less tires in the past but I would like to try the CRC PRO-CUTs but am not sure about how there compounds go (softest to hardest) is there a list of the different compounds and how they rank softest to hardest some where?
Thanks for your help
BIGBOT is offline   Reply With Quote
Old 02-23-2010, 08:13 PM   #641
PDX-Spike's Avatar
At the forward shock mount, I'm using a metric hex screw, an Xray hex ball and an Xray ball joint so I don't have to pry the cup off the ball. Works well, lasts forever. Thanks, Jacko!
Roger Christal - Team Timezone (Hooligans), Rose City Scale Racing, ROAR Member until 9/16/2012
Support the locals: Timezone Raceway, Timezone II, R/C Plus, Portland RC Raceway
McKune Design, Slapmaster Tools, Houston's Engine Service
PDX-Spike is offline   Reply With Quote
Old 02-23-2010, 09:24 PM   #642
CypressMidWest's Avatar
If you're familiar with Jaco's nomenclature, CRC's is similar. The only differences are Jaco's orange=CRC's Grey-Low, and Jaco's Double Pink=CRC's Magenta. Aside from that it's pretty much the same.
I generally run Yellow rears and Magenta fronts.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 03-03-2010, 09:18 AM   #643
Default Servo ???
I am trying to decide between 2 different servos. Futaba S9650 & Airtronics 94819.
The specs on the Airtronics is 1.26 x .63 x 1.26, .92oz, 33oz/in, .07/60.
The specs on the Futaba are 1.4 x .6 x 1.1, .9oz, 63oz/in, .11/60.
Airtronics stated that the 94819 is the new replacement for 94141 & 94145 (noted in the GenXL instruction manuel).
I see most are using the Futaba. Are the specs on the Airtronics acceptable?I also notice a little size difference. Need to know if any alterations would be needed to make it fit?
Old 03-10-2010, 05:25 PM   #644
Default gen xl ?
i have gen xl i ran on carpet. how will it work on asphalt or do i need a Tbar car and witch one? and is there any set up for brushless 1 cell lipo
thanks ronzo
ronzo is offline   Reply With Quote
Old 03-24-2010, 07:48 PM   #645
rcko's Avatar
Trader Rating: 15 (100%+)
ttt
rcko is offline   Reply With Quote
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
