Old 02-07-2010, 09:05 PM   #601
Trader Rating: 29 (100%+)
Mark,
I would try up to 1 degree of camber on the front and I have had good luck running less caster with 2 shims in front and 1 in the rear.
Hope this helps
Jason Hack
madhammer is offline   Reply With Quote
Old 02-07-2010, 09:23 PM   #602
CypressMidWest's Avatar
Originally Posted by Mark506 View Post
Ran the car today, for a smaller tight track, car handled quite well from coming straight from my 3rd round of the NEGS series setup from Tri-State. Quick question, the car wants to push when at high speeds, going into a tight 180. Now I know there's alot of momentum that's going to cause that, but it's not warping how I would like it.
Went from 5* to 10* blocks upfront, help a little, and worked well on other parts of the track, but still pushes at high-power. I'm looking for it to almost "Dive" better into the corner. I'm running -0.5 chamber in the front.
Are you running short-arm or long-arm? If long-arm, try going short. It'll give more camber gain, and thus more mid corner steering/rotation.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 02-08-2010, 02:01 AM   #603
TrevCoult's Avatar
Originally Posted by k_bojar View Post
seriously...unless you normally run motors lower then 5.5 turns, you don't need the RS Pro speedo...if you run the spec classes (13.5, 17.5, 21.5, even 10.5) you can do with the 'standard' RS speedo...
actually a lot of the team guys only run the RS speedos I know I do
+1
I've been running 10.5 with an RS for ages and there's nothing wrong with it. No difference in power to an RS Pro and it hardly gets warm
You really only need the RS Pro if you're running low turn modified motors.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 02-08-2010, 09:04 AM   #604
Mark506's Avatar
Trader Rating: 42 (100%+)
Originally Posted by madhammer View Post
Mark,
Hope this helps
Alright, I'm currently running all shims in the rear, so I'll give it a shot.
I'm running the long arms, So I'll throw the old ones on next time depending on how it feels. Thanks
Mark506 is offline   Reply With Quote
Old 02-08-2010, 09:58 PM   #605
Default Loss of rear grip
6 minutes into a run my Gen Xl gets real loose in the rear and I can barely drive the car the last two minutes. Any sugestions as to how I can fix this would be appreciated. I'm runiing 1s lipo with a 17.5 motor if it makes a difference. The first part of the run the car is awesome, just need to fix the last 2 minutes.
Bobinmt is offline   Reply With Quote
Old 02-08-2010, 10:22 PM   #606
Trader Rating: 41 (100%+)
Sounds to me like you have too much front grip and are working your rear tire too much. They loose compound too early. you could also have too hard of a rear tire. Depending on our track temp if it's above 70 degrees then I can run magenta rears with purple or pink fronts. If it's colder say 67 then I have to go to White rears and magenta fronts as I loose traction in the last 2 min. But I have a very aggressive handling car. I like it on the edge of rolling over. But that's just me.
Hope this helps.
jdeadman is offline   Reply With Quote
Old 02-08-2010, 11:02 PM   #607
What's your set-up, and what traction compound is used at your track?
Old 02-09-2010, 07:11 AM   #608
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Read what jdeadman wrote to you a few post up.
I look at how the front tires get a glaze. Getting a glaze on the front tires is gripping to much.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 02-09-2010, 07:36 AM   #609
Here again is my setup guide that I collected from all of the information gathered here on this forum, on Marc,s blog and others. This is not my work just a compilation of the information I use every race.
Attachment 552978
I hope that It's usefull
And if anyone finds any error please fell free to let me know. It's still a work in progress
Old 02-09-2010, 11:04 AM   #610
I'm running CRC yellow grey rears and CRC grey fronts
3/4 - 1 degree of negative camber 0 toe
10 degree caster blocks all shims to the rear
I'm utilizing the long front arm set up
.45 front springs white springs in the rear with 7000 in the tubes
Battery in the foward position
Gold rear shock spring
I try to set the car up with the front end about .25mm lower then the front.
Old 02-09-2010, 11:07 AM   #611
Attachment 552978
WOW this is awesome!!!!
Thank you very much..
Old 02-09-2010, 12:01 PM   #612
My Pleasure, I only started racing onroad last winter and I collected this info over that first year.
Old 02-09-2010, 05:52 PM   #613
I'd try black front tires. you may have to dope a bit more of the tire, and add a bit more camber, (maybe go to 1.5 degrees), but it shouldn't gain as much grip over the course of the run as the greys do. I might also try 10k in the tubes.
Old 02-10-2010, 04:09 AM   #614
Originally Posted by tfirsching View Post
When you turn the wheel on your radio, the very first reaction from your car is what I was referring to. When people talk about a car that is too sensitive or aggressive around center, it means that the car is making more of a turn than you want it to with the first tiny bit of radio input.
No. What I meant by race ready is - battery, motor, everything is in the car, the car is tweaked flat and you are ready to hit the track for a qualifier. Then you set the car on any flat surface and get down eye level with the front end. Observe the gap between the steering block and the lower arm. On my car it is about 1mm. If you set -1mm of front spring preload, your car would set down into the springs when it is setting on the wheels and that would probably turn into more like 3mm of front end droop.
Hi
I have been running the GENXL for a few meetings now. Previous car was a t-bar so its taking a little getting used to especially what does what to adjust the handling to my liking. The discussion about "about center" is interesting. Any tips on how to make the car less aggressive around center without losing overall steering. I typically run about -10% exp at the moment.
PeterA
petera is offline   Reply With Quote
Old 02-10-2010, 04:29 AM   #615
Yokomo_Ant3's Avatar
Originally Posted by petera View Post
Hi
PeterA
Make the front end stiffer, get the brace, it works very well. You could also try shimming the front of centre shock by 0.5mm. And .55 front springs
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
