Old 01-11-2010, 07:13 PM   #511
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
The little experience I had with CRC grey fronts (two sets) led me to feel they were a little more aggressive than a Jaco XXPink.
Old 01-11-2010, 08:07 PM   #512
GeorgePravata's Avatar
Trader Rating: 108 (100%+)
Default CRC GEN X
need some help about the new encore shock VS Vcs are the spring the same for both. Looking at nexus racing on CRC Gen X parts they show springs for the VCS(4) and they show (2) sliver and super sliver.
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 01-11-2010, 08:16 PM   #513
oeoeo327's Avatar
Trader Rating: 74 (100%+)
Springs are the same (rate and size) as the Associated VCS springs, but I haven't used anything stiffer than the red center spring. I've used the blue, gold, and red VCS springs with the Encore shock based on prevailing track conditions, but some tracks might warrant use of the silver or super silver center shock spring.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 01-11-2010, 09:21 PM   #514
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Default Tweak Plate Assembly
Hi all
Just got the Gen-XL and got to the Tweak Plate assembly and need some help.
Its pretty straightforward on the installing the tweak screws. Question is after I install the spring holder on the underside of the plate, how do I install the springs? It seems the diamter of the tapered side of the spring is smaller than the spring holder. do I simply force the spring onto the holder or is this incorrect?
Second Question is the Molded Center Pivot - When installed and checked for smotthness, I find the spot which gives me free movement allows slight movement of the pivot base. Is this correct? If I tighten the nuts 1/16th of a turn, the pod seems to bind at the center when rotating.
rinkrat99 is offline   Reply With Quote
Old 01-11-2010, 10:23 PM   #515
What tire setup do yall run? and the little 2 springs in the backk what color do you guys use and what is the difference between these colors?
I run pink front
grey back
And red springs
Clairvoyant16 is offline   Reply With Quote
Old 01-12-2010, 03:28 AM   #516
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Looking for some advice..
I am running this weekend in a big meeting, went out testing this evening on a track close to this weekend's race as in asphalt surface..
Normally race indoor where a gold spring and hard shock oil work perfect.
This evening my car donuts on just about every corner. Another driver there said my 45mm tyres and hard spring was one of the main reasons for this reaction.. Has anyone else had the same problem?
Also just a side question sorry if this has already been asked, someone said put a 2mm shim under the ballstud which the shock attaches too.. What effect does this have?
Alex
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
Old 01-12-2010, 04:05 AM   #517
Originally Posted by Mugen10 View Post
The purple servo mounts look like the old HPI pro 4 servo mounts.
Thanks, but they are a bit different. The mounts in the picture are "L" shaped and have 3 holes for moving the servo forward and backward.
Here is a better picture, as the previous one was not too clear :P
http://www.kimihiko-yano.net/weblog/...0090819-06.jpg
I have seen them in red too, but I cannot find a shop that carries them or the name of the brand.
-Edit: I think I found it. It seems they are re-anodized 12R5 servo mounts.
Ahmed Aman is offline   Reply With Quote
Old 01-12-2010, 07:23 AM   #518
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Alex
You Got PM
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 01-12-2010, 07:52 AM   #519
oeoeo327's Avatar
Originally Posted by rinkrat99 View Post
Hi all
Thread the center springs onto the holders by twisting the spring clockwise while applying light pressure.
Check the 2-56 buttonhead screws and make sure that they're not too tight. The pivot base shouldn't move when moving the pod side to side. You might want to revisit the instructions to make sure you get this adjustment right, otherwise the car will handle inconsistently.
Old 01-12-2010, 08:04 AM   #520
oeoeo327's Avatar
I run pink front
grey back
And red springs
Most setups call for white side springs, although I've used red springs for some tracks. Red is firmer than white, blue is softer than white. Green and purple are firmer than red, with purple being the firmer of the two; to summarize, softest to firmest is blue, white, red, green, and purple.
Tire choice really depends on track conditions, but a good rule of thumb is to use a rear tire that is 5-8 shore points softer than the front. Using Jaco's shore chart, gray rear tires typically pair well with purple or black fronts, and pink rears work well with double pink or lilac front tires.
If you're using CRC tires, it's tough to beat yellow rears and magenta fronts...
Old 01-12-2010, 12:47 PM   #521
WIITA's Avatar
Trader Rating: 42 (100%+)
Just so I know for the future, when do you use the Red side springs? I race on a tight track once and a while. Should I use them in this case? Also what tires would you use for high grip superstock? Thanks a lot!!
WIITA is offline   Reply With Quote
Old 01-12-2010, 01:57 PM   #522
oeoeo327's Avatar
Red side springs work well for tight tracks with lots of 180 degree turns, and for those days where you don't have enough front grip. I use the Associated 12R5 front end on my car, so my tire choices might be a little different than what you'd want; however, when I used the pro-strut front end, I typically ran Jaco pink rears and lilac fronts. If the grip REALLY comes up during the race, I'd switch to gray rears combined with either purple or black fronts. CRC yellow rear tires work well, but have a tendency to chunk - CRC gray-lows prevent this problem, but tend to lose grip at the 6-7 minute mark.
Hope that helps...
Old 01-12-2010, 08:53 PM   #523
rinkrat99's Avatar
Need some help with the Damper tube set screws. The 2-56 set screw appears to have no allen key socket. The key provided does not fit or is too small. Any idea what size this should be or is this a common problem?
Old 01-12-2010, 09:10 PM   #524
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
i had the same problem too...i think the allen key that's 'supposed' to work is indeed too small, either that or just very weak metal and stripped right away...I didn't have anything else in my collection of allen wrenches that would have works, so i just grabbed the set screw with my pliers and twisted it in that way
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 01-13-2010, 07:41 AM   #525
rinkrat99's Avatar
My allen key measures 0.032" so this might be the issue. Gonna have to find a 0.035" key somewhere. Maybe I can build up the side wall of the key or build up a wall on the setscrew.
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
