Old 12-29-2009, 12:18 PM   #466
PDX-Spike's Avatar
Originally Posted by kawirider View Post
i just need a pod link for my new XL and NO ONE HAS THEM? i have ordered some from CRC direct but they will never be here in time for the weekend. that sux. if anyone has even one to donate me before the weekend and can get it mailed by then, i would be forever grateful.
Broke one of my links. Made my own using the long Losi turnbuckles and some shock ends from an Xray (could have used ball cups). Just make sure the links are the exact same length as the original.
I like the new links better because they won't break and they add a little extra weight. Even so, I'm adding 21 grams of dead weight to the car just to get it ROAR legal.
Roger Christal - Team Timezone (Hooligans), Rose City Scale Racing, ROAR Member until 9/16/2012
Support the locals: Timezone Raceway, Timezone II, R/C Plus, Portland RC Raceway
McKune Design, Slapmaster Tools, Houston's Engine Service
PDX-Spike is offline   Reply With Quote
Old 12-30-2009, 11:04 PM   #467
CDW
Send a message via Yahoo to CDW
Originally Posted by Mark506 View Post
Just wondering, about how much drop is there in mah in the receiver pack? Around 90mah? thanks
Mark,
It really depends on what servo you are running. I know that the Futaba's use anywhere from 30-50 mah and the JR's use about 50-80 mah. I personally re-charge between every round, that way, I don't have to really worry about it.
Hope this helps,
CD
Team CRC/Team Matrix Tires USA/Fantom Racing/CDSUPERPRO/RK Designs/Access Hobbies & Raceway
CDW is offline   Reply With Quote
Old 12-31-2009, 01:56 AM   #468
My car pulls to the side when giving throttle checked the tweak its good any ideas
2011,2010 VORRA Club President
XRAY NT1
Mugen MRX-4X
GQ tires TMA marketing
Futaba
Rick1257 is offline   Reply With Quote
Old 12-31-2009, 03:40 AM   #469
WIITA's Avatar
Trader Rating: 42 (100%+)
First check the rear motor plate and make sure it's not bent. I have seen this happen a few times. Also check your rear axle spacing from center.
WIITA is offline   Reply With Quote
Old 12-31-2009, 09:48 AM   #470
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Maybe your diff is to tight. Also loosen all your pod screws and re-tighten them. Sometimes the pod can tweak and you not know it. Just to be on the safe side.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 12-31-2009, 10:22 AM   #471
Does anyone know the weight of the tubelube that CRC gives in their kits? Gen-X in specific?
asfastasu is offline   Reply With Quote
Old 12-31-2009, 10:43 AM   #472
TrevCoult's Avatar
White cap - 7K
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 12-31-2009, 11:24 AM   #473
whynot's Avatar
Trader Rating: 18 (100%+)
Maybe you have diff. axel ride height adjusters in the rear. just a guess
whynot is offline   Reply With Quote
Old 12-31-2009, 12:06 PM   #474
Trader Rating: 41 (100%+)
With on power wandering or torque steer I have seen that traction from side to side differences can cause it.
could be too much compound on one tire. Or different diameters of tire. and if it is pulling one way only then it looks like there is more weight on one rear tire and under load it will allow the inside one to slip.
check the balance of your car with and then without the rear pod attached (full race weight)
other than that if you are running a bit of toe out that can cause a wander under power.
jdeadman is offline   Reply With Quote
Old 12-31-2009, 09:56 PM   #475
CypressMidWest's Avatar
90% of the time this is it. Also check your center pivot for slop. A center pivot with side to side slop can cause this problem as well.
So:
1. Check tire diameter.
2. Make sure that the rear axle is properly centered.
3. Check center pivot.
4. Loosen all pod screws and "square-up" the rear pod.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 01-01-2010, 02:29 PM   #476
whynot's Avatar
I installing the graphite brace for the long upper arms and was wondering which way the brace goes on. does the cross bar go forward? and the counter sunk holes go up on the inside so the upper a arm mount can sit in it.So that means I need a button head screw to tighten this up? thanks
Old 01-01-2010, 04:59 PM   #477
Mugen10's Avatar
Are most people running the tweak springs just barley touching? The car is very centered so the springs does not even need to touch to get center.
Xray T4
Old 01-01-2010, 05:08 PM   #478
GeorgePravata's Avatar
Trader Rating: 108 (100%+)
Default GEN XL
I'm looking into getting an GEN XL can you tell if i still need to make the front end wider like i did on my old GEN X. Or does this kit have that already
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 01-01-2010, 06:50 PM   #479
CDW
Yes, you will need button head screws to tighten the Caster Block to the Front Brace. Sounds like you got it...
CD
Old 01-01-2010, 06:53 PM   #480
Mugen10's Avatar
If you want to run the long arms you will need to buy the extra parts. It is NOT included with the kit.
Xray T4
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
