Old 12-06-2009, 01:05 PM   #406
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Originally Posted by Mugen10 View Post
The white made the car feel to lazy for our small track. The red (firm) works really well. Oh well the green side springs seem a bit to stiff. I am not sure what conditions would be needed for a X firm spring. Maybe in mod with tight turns.
With the white side springs I'd run 5,000 in the tubes or lighter to get the car to transfer weight on a small track. I'd also run .45mm front springs with 3/4* camber. What tires did you run?
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 12-06-2009, 01:09 PM   #407
GasGod's Avatar
Hi all-- I just replaced my rear upper pod plate(after breaking the stocker)with the 4mm one.Should I raise the front shock mount to compensate for the thicker plate?
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 12-06-2009, 02:56 PM   #408
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
That is a good pod plate. I replaced mine as well (broke). It never occurred to me to shim up but it makes sense.
Sig,
I did go to the .45 front springs. I am also running 2k tube oil with the red side springs. Red center spring as well. The tires I am running at this time are Parma lilac and yellow. I am going to change to parma pink all the way around for club racing (less ware).
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 12-06-2009, 03:09 PM   #409
sg1
sg1's Avatar
Sig,
The pink rears and magents fronts would be a good combo. How much droop do you have in the rear and how much chassis rake do you run. I've had good luck with the stock gold spring, I usually don't change that much. You may also consider raising the front shock mount an additional 1/8" beyond the additional amount you have to compensate for the thicker top plate.
Old 12-06-2009, 03:12 PM   #410
Mugen10's Avatar
The rear droop is 1 mm. As for the rack I don't know what that is. I run the chassis and rear pod flat. I will look into the magenta tires.
Xray T4
Old 12-06-2009, 03:16 PM   #411
sg1
sg1's Avatar
I check the front of the chassis clearance, approx. 3.5mm, then again at the back of the chassis (not pod) and set that to 4.0mm clearance. So I'm at .5mm chassis rake. Dumps some weight forward for better stearing.
You could also go less rear droop for more responsive stearing.
Old 12-06-2009, 03:37 PM   #412
Mugen10's Avatar
I will give that a try. thanks
Xray T4
Old 12-07-2009, 10:15 PM   #413
303slowdown's Avatar
Trader Rating: 24 (100%+)
This might be a stupid question but im gonna ask it any ways . What efect does the stiffnes of the side springs have on the the car .i know they do something cause i can feel a difference but i cant put my finger on what it is,. Any help would be great thanks.
303slowdown is offline   Reply With Quote
Old 12-08-2009, 07:58 AM   #414
Mugen10's Avatar
A stiffer side spring reduces side roll. As the car rolls threw the corner the chassis tends to rotate to the outside. The stiffer springs keeps the chassis from rolling over.
Keep in mind you want some roll. Roll helps you to maximize traction and tire to surface. This is just the basics of chassis roll. Someone might be able to go into much more detail.
Xray T4
Old 12-08-2009, 08:01 AM   #415
artwork's Avatar
Trader Rating: 62 (100%+)
Side Spring:
Softer More side bite for rear end but will be lazier transitioning back & center.
Stiffer Less side bite. Faster transition but may feel edgy.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 12-08-2009, 09:04 AM   #416
Trader Rating: 41 (100%+)
We have Mid Tractions and I am running the following with great results
Front
Springs .45
no Lube
double pink or Magenta
4mm height
.5 degrees toe out
10 Degree reactive castor
-1 Degree camber
Trailing axle
Servo mounted low on the angled mount
Rear
White Rears rounded outside edge
Green Springs 0 -.001 turn preload
tubes 7000
4.5mm height
Center Red spring with 60wt
Running 19T on 4Cells turning 8.5 Sec laps on an 40x80 track
jdeadman is offline   Reply With Quote
Old 12-08-2009, 10:21 PM   #417
Frank you looked good on rctvlive.com
it was kind of hard to hear you talk soft.
microcrazy24 is offline   Reply With Quote
Old 12-09-2009, 06:49 PM   #418
Mugen10's Avatar
The green spring with 5k tube oil worked pretty good (for short tracks). I did not get a chance to see if it has faster lap times yet but will see next race day. Right now I am running Parma pinks all around. The wear is much better then the lilac and yellow. For club racing pinks seem to be the way to go for now.
Xray T4
Old 12-14-2009, 02:04 PM   #419
WIITA's Avatar
Trader Rating: 42 (100%+)
Hey guys. Wondering if crc makes front ride height spacers that are 2.5 or 2. I see the car comes with 3,4,5. Looking to start the tires at 41mm and if I do it will only give me 1 run per set. Any help would be great. Thanks!
WIITA is offline   Reply With Quote
Old 12-14-2009, 03:53 PM   #420
TrevCoult's Avatar
I was pitting opposite Elliott Harper last weekend at the Tamworth round of the UK 12th nationals. He was having his first time out with the Gen-XL. He finished 3rd in stock (10.5) and 4th in open modified which he was pretty happy with considering the car hadn't turned a wheel before Saturday morning and he was a little short of some things. Also pretty good with an unknown car considering the opposition included Andy Moore, Andy Griffiths and Olly Jeffries.
He was getting a handle on the car pretty quickly and ended up using a setup very similar to but not quite the same (as he told me) to Hupos at the IIC. Grip from the carpet is usually a little lower in the UK compared to the USA, hence the differences. He ended up saying it was the best 12th car he'd ever driven!
The only option parts I could see that he was using were the carbon front brace, long arms, pin brace and metal left pod side.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
