Old 11-10-2009, 06:27 PM   #301
aaron_buran's Avatar
Here is my XL setup from the Halloween Classic:
.50 fronts
10 degree blocks
20,000wt lube on the kingpins
no upper brace long arm
all shims back (max caster)
.5 degrees camber
servo up
CRC Magenta Front 1.60 Glued
Red Center spring
White Sides set "dead"
30wt oil in shock
10,000wt in one tube, 20,000wt in the other
CRC Hard Pink Rear 1.65
Batteries Forward
Ride Height 3.5mm in front and rear
1.5mm of pod drop
black art body
Advanced Speedo Control in rnds 3 & 4 and Main
Car was good despite the bumpy conditions, Q - 2nd, finished 1st
Horizon Hobby, JR Propo, Spektrum, Parma PSE, Faskolor, Tornado Racing Fuel, Calandra Racing Concepts, Murnan Modified Motors, Kyosho America
aaron_buran is offline   Reply With Quote
Old 11-10-2009, 06:56 PM   #302
Regional Moderator
CarbonJoe's Avatar
Why would you have different tube lube from one side to the other? Which tube was the heavier one?
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-10-2009, 07:12 PM   #303
KHoff7's Avatar
I would imaging to split the weight to 15000. It would not matter which tube due to the fact that they both move regardless of which way the pod tweaks around.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 11-10-2009, 07:12 PM   #304
The sides don't matter on the damper tubes, I wanted to achieve 15k (of which I didn't have), and I had 20 in them already, so I just changed 1 tube to 10k.
Old 11-11-2009, 11:19 AM   #305
If the CRC lubes are 1000wt, 3000wt, and 10000wt (red, white, & blue caps), what are people using for 20000wt or 15000wt?
Thanks,
Carter
darcydawg is offline   Reply With Quote
Old 11-11-2009, 11:21 AM   #306
KHoff7's Avatar
I use diff oils from 8th scale offroad cars.
Karl Hoffmeister
Old 11-11-2009, 11:30 AM   #307
Regional Moderator
CarbonJoe's Avatar
Thanks,
Carter
Most likely the OFNA diff lubes, since they seem to be readily available at most hobby shops that carry off-road buggies. Big bottles, and relatively cheap as well.
Old 11-12-2009, 12:23 AM   #308
R.Dalnogare's Avatar
Send a message via AIM to R.Dalnogare
Has anyone had ackermen problems. I'm using the kimbrough servo saver with a futaba 9650. The problem is when I turn right for instance, the inside wheel (right wheel) will be at its max angle, but the outside wheel (left wheel) will not be at its max angle, it has only rotated about 3/4 of its possible travel so its still pretty straight, and vise versa for turning left. I have tried all different servo positions, the old graphite knuckle pieces from the old car, spacers, ect and nothing works.
R.Dalnogare is offline   Reply With Quote
Old 11-12-2009, 04:55 AM   #309
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Ryan my car is the same way and it work great. I think you are worried about stuff that doesn't really matter. I know I had my car maxed out and when I put it on the track it wanted to spin out so I ended up cutting my steering throw almost in half. I would try the car first and if it doesn't work good then worry about that stuff.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 11-12-2009, 06:40 AM   #310
That is how the car should be. You should not be running that much steering anyway. 4 foot circles is pretty standard.
march to my own is offline   Reply With Quote
Old 11-12-2009, 06:56 AM   #311
I use Kyosho silicone diff oil in my tubes
I prefer the graphite horns on the sterring blocks over the plastic ones that come with the new XL, I think the steering geometry is better for me. However I do know that all the guys in vegas including Hupo ran the new plastic ones.
I agree 4 ft circle is a good place to start, at club races it's a bit smaller, and at big races, the circle gets bigger, due to the amount of grip.
If your car still pushes with a circle of 3.5 feet, you need to change the chassis and tire choice to generate more steering.
Old 11-12-2009, 07:18 AM   #312
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Aaron,
You have a PM.
-Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 11-12-2009, 02:28 PM   #313
Ffejdat's Avatar
I have noticed on a lot of Gen-X setups posted latlely that people are running very little front camber, like .5 degrees, versus 1.5 degrees for many other cars, why is this, or what does it do for your set up or handleing, thanks!!
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 11-12-2009, 02:43 PM   #314
CypressMidWest's Avatar
More camber will usually increase steering mid-corner. For instance, on the rare occasions I run long-arm, I run between 1 and 2 degrees camber because the car has less camber gain, and therfore less mid-corner steering. I usually run short-arm, and run between .5 and 1 degree, because short-arm naturally has more camber gain, and therefore more mid-corner steering. Hope this helps.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 11-12-2009, 04:33 PM   #315
al dente's Avatar
Ian...How much camber do you run on your luggage cart?
Looking forward to gridding up with you in cleveland. I am glad we are both running stock...this way the only way you can ruin my race is to hack me.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 19-22, 2018
al dente is offline   Reply With Quote
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
