Old 10-17-2009, 06:20 AM   #151
WIITA's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Stealth_RT View Post
You must have some oddball crazy narrow front wheels, if you can put spacers on the outside of the wheel and still be on the thick part of the axle. What brand are you using?
With Jaco front wheels, I put the three shims on the inside like the manaul calls for. The outer bearing sticks out past the thick part of the axle slightly. If I tighten the wheel nut up all the way, it locks up the bearings.
no just using the crc tires. Wonder if its better to have the shims on the outside so it wont mess with the width of the wheels?
WIITA is offline   Reply With Quote
Old 10-17-2009, 09:39 AM   #152
Trader Rating: 37 (100%+)
Anyone know if CRC sells a full screw set (steel or Ti) for the GenX/XL? I've been rounding out the red aluminum ones, and lost a bulkhead screw at the last race. Didn't see a full screw set as an item in their store...
"Fermentation may have been a greater discovery than fire."
-David Rains Wallace
jubilee is offline   Reply With Quote
Old 10-17-2009, 10:24 AM   #153
mkdut's Avatar
Trader Rating: 19 (100%+)
Bill go to Fastener Express and order the sizes you need. They have both aluminum screws and some titanium though it looks like they are a out of some of the ti screws right now. Slowly converting mine to all titanium.
http://www.fastener-express.com/
mkdut is offline   Reply With Quote
Old 10-17-2009, 10:52 AM   #154
We do not have a steel screw set as of right now. We do sell packs of all the steel screw sizes. All the part numbers are listed in the manual. The only Ti screws we sell are the 4 for the front end part #12393.
We do sell a red aluminum screw set part number 1410.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 10-17-2009, 12:00 PM   #155
thanks guys, much appreciated!
Old 10-17-2009, 12:23 PM   #156
Originally Posted by dumper View Post
Part numbers:
3351 - Plastic micro bilkhead
3353 - Aluminum micro bulkhead
1766 - Bottom plate
3290 - Encore Shock
The shock is not needed for the conversion, use can use your existing Dura-Shock if you want by trimming a little off the ballcups to shorten the shock a little.
All parts are in stock at www.teamcrc.com
dumper
Just double-checking before I order Part # 1766...the picture on the CRC site does not match the product, correct? The two small rear holes for the micro pod plate are not shown. Thanks for clarification!
Old 10-17-2009, 04:04 PM   #157
myrxseven's Avatar
myrxseven is offline   Reply With Quote
Old 10-18-2009, 06:51 PM   #158
WIITA's Avatar
Anyone have any suggestions on getting the springs on the perches. when I turn the set screw it looks like it's on crooked. I put the set screw and the perch on the screw right. Just wondering what everyone does. Thanks.
Old 10-18-2009, 08:40 PM   #159
whynot's Avatar
Trader Rating: 18 (100%+)
Originally Posted by sg1 View Post
With the CRC tires I add more shims. I have 6 of the kit shims on the inside and none on the outside. It is nice with the axle being longer for fine tooning track width in the front. With the springs, I just rotate them around untill they are engaged on the perches and hang off straight. If you "over rotate" them they will try to thread on and sit crooked.
Help this helps,
Wayne
here is your answer
whynot is offline   Reply With Quote
Old 10-19-2009, 03:53 AM   #160
WIITA's Avatar
Originally Posted by whynot View Post
here is your answer
Great thanks
Old 10-19-2009, 06:43 AM   #161
There was a running change to the part. Part #1766 now has the holes to accomodate the older big left side pod plate, or the smaller micro left side pod plate. So this part will fit everything you might have.
Old 10-19-2009, 10:07 AM   #162
Thanks again, placed my order.
Old 10-19-2009, 08:13 PM   #163
CanyonCarverR1's Avatar
What servo do you guys recommend? Looking to place an SPX behind it.
CanyonCarverR1 is offline   Reply With Quote
Old 10-19-2009, 08:16 PM   #164
myrxseven's Avatar
JR3650
Old 10-19-2009, 08:18 PM   #165
CypressMidWest's Avatar
I'm running a Futaba 9650, the JR 3650 is also a good choice.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
