Old 10-13-2009, 08:12 PM   #136
DHMOTORSPORTS's Avatar
Trader Rating: 19 (100%+)
Originally Posted by whynot View Post
Anyone know where they have the gen xl kits in stock? thanks
mike
Rcbibs.com had some today when I called earlier..
Trinity / Team Epic / ReVtech Batteries / TRC / F-Bomb Graphix
DHMOTORSPORTS is offline   Reply With Quote
Old 10-13-2009, 11:56 PM   #137
roadkill's Avatar
Trader Rating: 139 (100%+)
Send a message via Yahoo to roadkill
I bought a conversion kit for my gen x, and also a molded center pivot ball,
I was wondering if the pivot ball that comes with the gen xl kit ,is different than the reg gen x pivot ball? anyone know? thanx for your time
Keeper of the check book, Pit butler,(for hire) President and life long member of the Black Flag Club,
roadkill is offline   Reply With Quote
Old 10-14-2009, 09:20 AM   #138
CDW
Send a message via Yahoo to CDW
After looking at both manuals, it is the same pivot ball PN 4019. They do offer a Hard Anodized pivot ball PN 40194
Hope this helps,
CD
Team CRC/Team Matrix Tires USA/Fantom Racing/CDSUPERPRO/RK Designs/Access Hobbies & Raceway
CDW is offline   Reply With Quote
Old 10-15-2009, 06:26 AM   #139
Yes, they are the same exact thing.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 10-15-2009, 09:34 PM   #140
buffalobill989's Avatar
Trader Rating: 50 (100%+)
for you guys thats upgrading to the XL, its just the conversion kit, the encore shock and the left side bulk plastic bulkhead right? where are you guys getting the bulkhead? i wonder if there will be an aluminum one come out. i can find it all but the bulk head. thanks
buffalobill989 is offline   Reply With Quote
Old 10-15-2009, 09:58 PM   #141
Capt'N_Slow's Avatar
You will need the new rear pod bottom plate with the two small holes located in the back of the plate and you will also need the micro aluminum left bulkhead.
The part numbers for these items can be found in the battle axe 2.0 manual published on crc's website.
Micah
Capt'N_Slow is offline   Reply With Quote
Old 10-15-2009, 10:11 PM   #142
thanks alot looks like i will be ordering some parts
Old 10-16-2009, 06:43 AM   #143
Part numbers:
3351 - Plastic micro bilkhead
3353 - Aluminum micro bulkhead
1766 - Bottom plate
3290 - Encore Shock
The shock is not needed for the conversion, use can use your existing Dura-Shock if you want by trimming a little off the ballcups to shorten the shock a little.
All parts are in stock at www.teamcrc.com
dumper
Old 10-16-2009, 08:33 AM   #144
thanks alot. is the molded pivot something i should upgrade or will the carbon fiber one i have now work? is there any upgrade to doing this?
Old 10-16-2009, 09:24 AM   #145
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I'm still using the old one. There is no advantage to the new one.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is online now   Reply With Quote
Old 10-16-2009, 11:19 AM   #146
The molded pivot is nice because of the adjustability. You can always keep the fit of the ball perfect, so in that regard it is better than the old one.
Gotta have- not really
Nice to have - yes
Old 10-16-2009, 02:56 PM   #147
WIITA's Avatar
Trader Rating: 42 (100%+)
Hey there guys. Just finished putting the kit together and noticed two things. 1) no matter how tight I tighten the front axle lock nuts I can't seem to stop the tire from sliding side to side. I have 2 spacers on the inside of the wheel and 2 on the outside and it still slides a little side to side. Do I need to order more spacers to put on the outside? 2) I have tried so hard to get the springs on the perches and I just can't seem to get them on perfect. Any suggestions?I think they are seated in the slot on the perch too. Do they make optional perches you can buy? Otherwise the kit is great and I think the front end is wonderful in how you can eliminate all the slop as it wears.
WIITA is offline   Reply With Quote
Old 10-16-2009, 03:19 PM   #148
Nice to have - yes
Good point. I'll add one and the hardened pivot ball to my spares for both cars.
Old 10-16-2009, 09:30 PM   #149
You must have some oddball crazy narrow front wheels, if you can put spacers on the outside of the wheel and still be on the thick part of the axle. What brand are you using?
With Jaco front wheels, I put the three shims on the inside like the manaul calls for. The outer bearing sticks out past the thick part of the axle slightly. If I tighten the wheel nut up all the way, it locks up the bearings.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 10-17-2009, 04:24 AM   #150
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
With the CRC tires I add more shims. I have 6 of the kit shims on the inside and none on the outside. It is nice with the axle being longer for fine tooning track width in the front. With the springs, I just rotate them around untill they are engaged on the perches and hang off straight. If you "over rotate" them they will try to thread on and sit crooked.
Help this helps,
Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is online now   Reply With Quote
CRC GEN X, REV 5, AND CUSTOM PAINTED 1/12 BODY FOR SALE ALBERTO R/C Items: For Sale/Trade 40 12-23-2008 08:21 PM
!!!!! CRC Gen-X, Novak GTB, Etc, Etc !!!!!! omaha_racing R/C Items: For Sale/Trade 31 02-04-2008 03:47 PM
---CRC Gen X w/ Parts and Extras!!!--- AChupp2 R/C Items: For Sale/Trade 6 10-25-2007 01:07 PM
TEAM CRC GEN-X GENERATION X patrick R/C Items: For Sale/Trade 6 07-29-2007 12:15 AM
CRC Gen-X 1/12 w/ TONS of NIB Spares Anthony.L R/C Items: For Sale/Trade 23 04-13-2007 09:48 PM
CRC Gen X - Complete roller - almost new! Team Speed R/C Items: For Sale/Trade 11 04-11-2007 02:41 PM
