Measuring Droop
#16
Ride height 5mm
Downstop setting (difference between chassis and arms, adjsuted with the screws in the suspension arms) 6mm (a downstop setting of 6)
Droop 2mm (how far the car lifts before the tires come off the ground
Now, without changing anything else, tighten your shock collars ALL the way down so the are as tight as they go, which would MAX out your ride height. Lets say that makes your ride height 7mm. You would end up with the following:
Right height 7mm
Downstop setting 6mm
Droop 0
So droop, and what you are changing with the grub screws in the suspension arms of the car, are two completely different things.
#17
My downstop IS my droop. If it isn't then the supension is binding somewhere and thats no good. On my car, downstop minus ride height = droop. So from my thinking, downstop and droop ain't exactly apples and oranges. They're closely related.
#18
No, because they are apples and oranges and dont measure the same thing. Here is an example I always use. Lets set up an imaginary car like the following:
Ride height 5mm
Right height 7mm
Droop 0
Ride height 5mm
Right height 7mm
Droop 0
I run rubber tires and always run the same ride height front & rear and I always start with the same "down-stop" setting. No need to know what the "droop" is unless I need to compare my setup with someone else with a different car.
At times I forget about foam tire racing (I never tried it)...
#19
cpt.America is completely right.Downstop and droop are two different things,closely related but not the same as they don't measure the same thing.
