Old 08-27-2009, 02:44 PM   #1
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
Default CRC 1/12 Gen X Disscussion
After hunting around for a bit and asking some other members in various threads, no one could link to me a specific CRC Gen X 1/12 .
So, to get things started, what is a common starting setup that people have settled on for the Gen X?
What are some parts to have in your pit box with part numbers?
What foam bumpers fit properly on the Gen X?
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 08-27-2009, 02:47 PM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
Well, except for a few front end tweaks I am running a basically stock set up. I haven't gone lipo yet but hope to do some 1s lipo testing saturday.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-27-2009, 02:50 PM   #3
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Don't know what items you should get but I was shopping for CRC Pro-strut for an older CRC car and couldn't find it on their website but I found all sorts of CRC parts at Nexusracing.com There were various bumpers available.
YR4Dude is offline   Reply With Quote
Old 08-27-2009, 03:07 PM   #4
Tech Legend
Cain's Avatar
thanks for the info! I got a used Gen X in in good shape with the brushless rear pod and some tires. Just need to see what is a good setup, confirm if I have the parts to do it, and go from there. I plan to do 1S lipo.
Old 08-27-2009, 03:47 PM   #5
nashrcracer's Avatar
R/C Tech Charter Subscriber
converted my xforce to genx with lipo still don't like how it keeps turing when I let off. what side springs are you guys using on a lowbite carpet track?
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 08-27-2009, 05:53 PM   #6
Setup for a GenX is pretty simple for carpet.
Red main spring, White side springs, 0.018 front springs. Heavy tube lube, and 30WT in the main shock. 10deg castor blocks (2 washers rear, 1 forward), and 2 deg camber. 1 deg toe out. Run black fronts, white or gray-low rears.
Shawn.
Shawn68z is offline   Reply With Quote
Old 08-27-2009, 11:13 PM   #7
DriftDreamer06's Avatar
Shawn.
.018 front springs? i thought the size was a 50 on the package and .018 was assoc spring?
is that a 4cell setup or 1s?
what ride height f/m/b?
DriftDreamer06 is offline   Reply With Quote
Old 08-28-2009, 05:48 AM   #8
is there any news about revised chassis plate(s) from CRC? specifically I would be interested in a main chassis plate that's pre-drilled to accept CRC's new long side links (similar to those on the Assoc 12R5) and perhaps a chassis that's milled or otherwise designed for the new 1cell lipo packs that everybody is going to. Anybody heard if such revisions and update parts are in the pipeline?
vafactor is offline   Reply With Quote
Old 08-28-2009, 08:15 AM   #9
wingracer's Avatar
I heard it is in the works. No idea on a timeline.
Team Shepherd USA
Old 08-28-2009, 08:19 AM   #10
Tech Legend
Cain's Avatar
got a part number on the heavy tube lube?
Old 08-28-2009, 08:21 AM   #11
fatboy's Avatar
Send a message via MSN to fatboy
any idea where could i get the rear body post for my carpet knife.... any link ???
fatboy is offline   Reply With Quote
Old 08-28-2009, 09:05 AM   #12
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
1,400 posts Gen X 1/12
http://www.rctech.net/forum/electric...-thoughts.html
Tire Chunker is offline   Reply With Quote
Old 08-28-2009, 09:17 AM   #13
Tech Legend
Cain's Avatar
thanks. Will post in there instead.
Old 08-28-2009, 11:31 AM   #14
Your right. Darn metric! On the GenX front end its the .45mm (the real soft ones). The .5mm is closer to the .20 spring.
I start the night with 4mm ride height, car is flat. 1mm droop for the rear pod. By the end of the night (3 quals, 1 main) I am borderline 3mm (which is our clubs minimum height)
4Cell setup. I dont plan on making any changes for the switch to 1S, unless I have to.
Shawn.
