Old 09-15-2010, 04:12 PM   #61
lil3j's Avatar
Trader Rating: 60 (100%+)
Send a message via AIM to lil3j
Originally Posted by dzstr View Post
Has anyone used the USB programmer with 64bit Vista? I downloaded the installer from the TP website and installed but when I plug in the programmer the driver is not found.
I've tried and tried and can't seem to get mines to work either. So I just use the home pc with xp and it loads right up
CMH Customs
(Brian) Colonial Photo and Hobby
2 Lanes 1 Winner
lil3j is offline   Reply With Quote
Old 09-15-2010, 05:36 PM   #62
Recoiled Revo's Avatar
Send a message via Yahoo to Recoiled Revo
Originally Posted by hound_dogs_01 View Post
i figured it out my cut off was 3.9V per cell... which is 7.8V so it was under the cut off voltage... so when i went to discharge it it read it as a voltage error...
those instructions do come in handy lol
thanks for the replys guys!!!
Pakk youll have a PM in about 2 mniutes my good man
Alex
I had that problem and found that the battery was not balanced correctly so I had to put the charger into recovery mode and it fixed the problem.
Life is short play hard!!!!!
HB Tekno VE8
HB Tekno D8Te
ASC RC12R5.2 Blinky
ASC TC6.1
Recoiled Revo is offline   Reply With Quote
Old 09-17-2010, 07:41 PM   #63
Bubblehead's Avatar
Originally Posted by ThunderPowerRC View Post
On the V5.6 and newer firmware. Plus mode or compitition mode is in the set up part of the charger. With the setting in 100% charge and the Plus/ Comp mode it with change the charge cure and raise the cutoff to 4.2v per cell. V5.6 and 5.7 only do this in 2 cell mode. V5.8 will do 1-4 cells.
How do I get my batteries to come the charger at 8.4V? Or should I buy a new charger that I will be legal to race.
Bubblehead is offline   Reply With Quote
Old 09-18-2010, 10:38 PM   #64
oXYnary's Avatar
Send a message via AIM to oXYnary Send a message via Yahoo to oXYnary
Sounds like you quoted your own answer. What version of the firmware are you using?
www.3drcracing.com <<RC Video Game.
Kyosho Mini-Z Buggy, Moto Racer | Losi Micro SCT, 8ight Mini
oXYnary is offline   Reply With Quote
Old 09-19-2010, 05:32 AM   #65
Bubblehead's Avatar
I have V5.6, I had to turn off the Plus Charge mode. The manual should explain Plus Charge mode.
Old 09-19-2010, 01:16 PM   #66
oXYnary's Avatar
I believe those were added after the manual was made. IE the manual needs to be updated.
Anyhow fwiw they are up to 6.0 now.
http://thunderpowerrc.com/html/download.htm
* Along with the 'LiPo CHG Option' (LCO) selections of FAST charge, 50% storage, 95% charge and 100% charge modes, an additional and separate menu option feature listed as 'COMPLETITION CAR MODE' (CCM) has been added. When CCM is turned ON the profiles for the constant current (CC) and constant voltage (CV) phases of the charge process have been further optimized to ensure that the charge capacity/voltage of the battery is at the safest maximum allowable specs authorized by many racing organizations (and does not charge the cell/battery beyond 100% capacity/voltage)
CCM Mode is only active when turned ON and when charging 1S 3.7V to 4S 14.8V batteries (not 5S 18.5V and 6S 22.2V batteries). Also, when CCM is turned on it will take precedence over any LCO that has been selected. For example, if CCM is turned on and LCO selection has been set to 50% Storage the cell/battery will still be charged fully using the optimized CC/CV profile. As a result we recommend that CCM is turned on only when needed and if charging cells/batteries for use in competition car/truck/buggy racing. It is not necessary to use CCM when charging batteries for any other applications.
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 06:31 PM
Thunder Power Rc 40C 5000 Lipo ThunderPowerRC Electric On-Road 439 02-25-2010 04:35 PM
Werks, Chargers, M8 parts, Diecast Cars, Trophy, Other Stuff ade R/C Items: For Sale/Trade 26 07-26-2009 05:13 AM
FS Thunder Power 1010C charger and TP-210V Balancer ffpm46 R/C Items: For Sale/Trade 22 09-05-2008 08:37 PM
