Thunder Power TP-610C Charger >
Old 08-25-2009, 12:45 AM
  #31
Johnny Wishbone's Avatar
Wow, thats weird. I run the same packs (SMC 6000/28C) and rolled my TP610 back to 5.5 software and it only gives me 8.39.......just weird.
Johnny Wishbone is offline
Old 08-25-2009, 12:51 AM
  #32
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
I no longer have the packs other wise I would charge and show pics... Both packs had a balance wire break, sent them in and I got back 2 new 5400/24C packs, since theyre no longer producing the 6000/28C packs....
How hard is it to update firmware? What are the steps to do so?
Alex
hound_dogs_01 is offline
Old 08-25-2009, 01:05 AM
  #33
Download, open zip file, run exe, done. Charger has to be on the power supply to write the software over, takes about 15-20 seconds.
Old 08-25-2009, 01:21 AM
  #34
thanks Johnny!!!! i should have the 5.7V by the end of the week I'm guessing.... Depending on how long it take to get an e-mail back from thunder power
Alex
Old 08-25-2009, 09:21 AM
  #35
m8commando's Avatar
I have 2 thunder Power 610-C's chargers in excellent condition....and thunder power battery pack almost new 40c 5000. Please go to For sale thread!
m8commando is offline
Old 10-20-2009, 07:49 PM
  #36
NOFX's Avatar
Trader Rating: 25 (100%+)
Hi
I just wanted to ask people who use this charger, if being able to charge at 10 amps is worth it, i normally run 5000mah packs, maybe using 2000-2300 mah in a race, so normally with my 5 amp charger it takes around 25 mins to top the lipos back up, can i expect the thunder power charger to go close to halving that, to around a 15 minute top up time, my packs are all at least 2c charge rate, i know on a lot of chargers (swallow for example)the time taken at the end of the charge is really long, is this the case with the thunderpower?
thanks in advance for any help you can offer
NOFX is offline
Old 10-21-2009, 10:17 AM
  #37
R/C Tech Elite Member
JayL's Avatar
Originally Posted by NOFX View Post
Hi
it's more like a 25% savings of time...when you ramp up higher, 10 amps, it takes longer to come back down to 0
JayL is offline
Old 10-23-2009, 11:23 PM
  #38
rinkrat99's Avatar
A quick question for you TP610 owners. I have been charging a 4900pack after a race on a Multiplex set at 1C. I noticed that the charger will move out of CC mode before 4.1V per cell. At 4.2V the CV is at 1 A thus taking it very long to recharge 2200 mA. How does the 610 do for a CC/CV profile? Will it hold at 1C until 4.2V or does it drop sooner?
rinkrat99 is offline
Old 10-24-2009, 08:40 AM
  #39
I have two of the 610C's and have been using them for 1 cell packs. I have charged at up to 8 amps and it holds the 8 amps all the way to 4.2 volts. have upgraded to 5.7 but as we know that doesnt have the higher voltage for 1 cell yet. So far the chargers have worked well.
slotracer577 is offline
Old 10-24-2009, 10:02 AM
  #40
adamge's Avatar
rink, something must be set wrong. It should hold the full charge rate (Amps) until it hits 4.20V per cell. It might start displaying "CV" before 4.20, but shouldn't slow down until then.
adamge is offline
Old 10-24-2009, 05:52 PM
  #41
JimmyMac's Avatar
Competition mode doesn't matter anymore (at least for Roar races) because new Roar rules state battery voltage cannot go above 8.4v for 2s lipo and 4.2v for 1s lipo for the 2010 rule book.
But anyways, mine will hold high amp charge rate until it gets close to the voltage where it will then taper off the amperage.
JimmyMac is offline
Old 10-25-2009, 08:56 AM
  #42
Some of us dont race roar and with the Tour rules at 4.22 for one cell, would like a bit more than I am getting now. Once the charger shuts off, the packs drop down to 4.19, 4.17.
John
Old 10-25-2009, 10:48 PM
  #43
rinkrat99's Avatar
Thanks for the feedback.
FYI - The MultiPlex has a soft charge cycle. There cutoff is at less than 4.2 and I think its 4.1 but mine seems to be less than that.
The MultiPlex is a much safer charger in terms of the charge profile but takes a while to complete a charge cycle.
Old 10-26-2009, 07:16 AM
  #44
Is there any way to balance charge two 2s batteries at once? It would just be a matter of hooking up to the 4s with the right cable right?
Brian Bosley is offline
Old 10-30-2009, 08:48 AM
  #45
This does work, you can charge two as a 4S using a Y adapter on the main power lines and then a 6s adapter with the correct pins for the balancer. You are still basically using the balance leads to hop between cells, so one battery has one less wire and you end up with 5 going into the 6s (7 wire) tap.
