Old 08-23-2009, 01:13 PM   #1
Trader Rating: 32 (97%+)
Default Weird LRP related issue
So im having some crazy problems with my AI LRP speed control. Im running it in a VTA car with a novak SS 21.5 motor first off and a 33/83 gear ratio giving me a final drive of like ~5.0. The problem Im having is that after about 10 minutes the car shuts down for about 5 seconds, flashes its light on the speedo then will run for about a half lap and do it again. When I temp it, its only temping @ 120 degrees on the motor and about 100-110 on the speedo. I've tried 2 different batteries making sure to eliminate that as a possibility. Every once in a while the speedo will also just randomly reverse itself. What could I do to solve this? I opened up the speedo and there was some carpet fuzz in it, so I cleaned it all out.
kikcaffine is offline   Reply With Quote
Old 08-23-2009, 03:20 PM   #2
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
Mabe a call to LRP can solve your issues Chris....
Alex
hound_dogs_01 is offline   Reply With Quote
Old 08-23-2009, 03:25 PM   #3
Alex
BAMBAM cheapsk8 is offline   Reply With Quote
Old 08-23-2009, 03:38 PM   #4
Mail them.
If you are lucky they will respond in 2050 on your mail
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 08-23-2009, 03:43 PM   #5
Originally Posted by mikky32 View Post
Mail them.
lol
Do I call associated, are the the US distributers for LRP?
Old 08-23-2009, 04:08 PM   #6
Not familiar with your ESC, does it have adjustable settings? I had a similar issue w/ the SPX where it was set for lipo batteries but I was running NiMh due to not having the 21.5 motor. Check the setting if there is one. Mine was basically shutting down the receiver due to low voltage.
Tiger72 is offline   Reply With Quote
Old 08-23-2009, 04:11 PM   #7
Con
Here is the fix....Junk the LRP and buy a TEKIN
Con is offline   Reply With Quote
Old 08-23-2009, 04:19 PM   #8
It does, I currently have it set for lipo mode. When it shuts the car off the battery still has over 8 volts in it.
Old 08-23-2009, 04:21 PM   #9
Are they the ones who gives the military discount? Or who is it?
Spektrum allrc Radio and Electronics 2545 07-17-2012 09:25 AM
