Old 08-23-2009, 03:18 PM   #16
bvoltz's Avatar
Trader Rating: 44 (100%+)
Originally Posted by abailey21 View Post
What version s/w are you running?
How do we get the software and software update? I'm not finding it on the web site.
bvoltz is offline   Reply With Quote
Old 08-23-2009, 03:26 PM   #17
dameetz's Avatar
Look into the 'apparel' section...it may sounds funny but it is there.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 08-23-2009, 05:46 PM   #18
bvoltz's Avatar
Many thanks, interesting....
Old 08-23-2009, 05:48 PM   #19
bvoltz's Avatar
How do you tell what version on the Speedo? I purchased about 2 years ago... it is the GT... With out the programmer....
Old 08-23-2009, 06:38 PM   #20
cyanyde's Avatar
2 years?? Are you sure its the 2.0? Only the 2.0 comes with updateable firmware. It may be the 1.0 or 1.1, which is not updateable. Still, the older versions aren't bad esc's.
cyanyde is offline   Reply With Quote
Old 08-24-2009, 02:41 AM   #21
amnesia's Avatar
Originally Posted by Marcos.J View Post
are you running 0 timing on the esc??
Yep... although it doesn't seem to run any faster if I change it to anything else.
I am beginning to think that the timing in the ESC is faulty, permanently running it too advanced.
I have contacted the UK supplier today to see if they have any advice.
Daniel.
.-= T.O.P. Photon =-.
Titanium Racing (Team TR Driver) / Tekin RS Pro / Novak Ballistic 13.5t / Spektrum
www.titaniumracing.com
amnesia is offline   Reply With Quote
Old 08-25-2009, 12:37 PM   #22
still have problems with mine , nothing binding at all , set gearing as per my motor (4.8-6 FDR) and its still gets extremely hot , do i really have to buy this LCD program unit to solve this ? or will i end up getting it and still get the same problem after ?
madwestmo is offline   Reply With Quote
Old 08-25-2009, 02:44 PM   #23
razzor's Avatar
check if anyone at your track has a lcd programmer and hook it up to a pc or laptop to check.
Try changing the DRSS to a lower setting might be to aggressive for your driving style.
Cant speak for gear ratio but guys at my club are rolling out anything from 42mm to 47mm
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
