Ratio
Old 01-26-2004, 08:34 AM
Ares17's Avatar
Default Ratio
How to calculate the drive ratio....like what kind of pinion and spur is good for reedy krypton 10 turn/single? Thank you.
Ares17 is offline
Old 01-26-2004, 11:46 AM
Default Re: Ratio
need to know what kinda car your driving ???????
mb racer is offline
Old 01-26-2004, 11:54 AM
Default Re: Re: Ratio
and trannie ratio???
mb racer is offline
Old 01-26-2004, 12:34 PM
mo
mo's Avatar
Check out this site for a great gear ratio and rollout calculator.
http://www.gearchart.com/
mo is offline
Old 01-26-2004, 04:56 PM
Ares17's Avatar
heheehe...sorry. I fall out on that one. I may be running the hpi pro 4 or the mr4tcsd., with the 10 turns motor
. So how do I calculate the ratio?
Ares17 is offline
Old 01-26-2004, 07:05 PM
Sal Amato's Avatar
Trader Rating: 27 (100%+)
Default GEAr RATIO
To calculate gear ratio : SPUR div PINION
To calculate final drive ratio: GEAR RATIO x TRANNY RATIO
So What ever car you get you must find out the tranny ratio.
EXAMPLE: TC3 tranny ratio 2.5
SPUR 100 div PINION 30=3.333=GR
GR 3.333 X TR=8.33=FDR
YOU then use FINAL DRIVE ratio to figure rollout
HOPE THIS HELPS
Sal Amato is offline
Old 01-26-2004, 08:21 PM
Ares17's Avatar
sns820,
thanx bro. it sure helps.now i know.
Ares17 is offline
